302 swap is about to go down!
Old 09-18-2007, 05:42 PM
Kaleb's Avatar
Originally Posted by Kiff
Will the R150F hold up to the power of a 5L HO? I mean for a trans that was meant for 150hp now getting near double that.
Finally a swap worth subscribing to. I am sick of hearing about the 3.4 swap fad.
Old 09-18-2007, 05:56 PM
Victor's Avatar
I would say the R150 will hold up. Plenty of guys have supercharged 3.4's in front of them. I've seen a couple of Turbod Supra motors in front of it also
Old 09-19-2007, 02:38 PM
Kiff's Avatar
What other tranny options do we have? "would say" is not much better than "I don't know". Anyone have and solid info to back up the transmission issue?
Old 09-19-2007, 02:46 PM
Gator's Avatar
Originally Posted by Victor
Is there an adapter that can go between the AOD trans in the car and the Toy transfer case? Just offering an option since you already have a usable trans sitting in the car.
Check out Downey's catalog (they don't appear to have kits for Ford engines, but they have a lot of good advise) . Although They refuse to make an adapter for the engine and Toyota trans due to the torque the engine will be putting out. The Toyota trans was built to handle 160lb-ft of torque, 300 will certainly destroy second gear unless you just baby the hell out of it. It kind of defeats the whole purpose of doing the swap. Go with the auto in the car, or find a stick for cheap. Can't go wrong either way. Check out the link below for more good info.
http://www.mindspring.com/~jayk3/toyota/swaps.htm
Old 09-19-2007, 02:57 PM
  #25
Victor's Avatar
I think the R150 can handle it. If you like doing burnouts or really running through the gears hard then it won't but otherwise it should be good for everyday use.
Old 09-30-2007, 08:33 PM
  #26
jmcbmx's Avatar
well i picked up my transmission fri i got a rebuiltC4 out of a 70 something mustang. the guy said it was out of one of his sons buddys cars and needed it out. he says it only has 5k miles on the rebuild, and ran fine when it was pulled. but he didnt know why it was pulled? i'm not real concerned i'm gonna have my girlfriends dad go through it put the shift kit in it and put the adapter on. i havent decided which adapter kit to go with yet advanced has one and northwest offroad has one for about 50 bucks cheaper. Oh yeah the best part is i only paid 80 bucks for the tranny and the guy met me at my job and dropped it off. it came with a torque converter so hopefully i'll be able to get the stall bumped up on it as well. i got my truck all torn apart its comin along nice. the motor, t-case and trans are all out of it. Ive been lookin and i think it will be really easy to belly tuck it while i'm doin this so i'm gonna make a crossmember for it and try to hopefully get the bottom of the t-case about flush with the frame rails or maybe an inch below and i got some i think 1/2 x 4 bar stock steel for free so i'm gonna try to use it for the crossmember. i had planned on puttin a bunch of pics up but my camera is dead. so i'll prolly get them up sometime this week. I also ordered my 4.7 gear reduction kit and some 1.5 inch wheel spacers. they were trying to convince me to go ahead and order the IFS eliminator kit to from trail-gear but thats a little on down the road, but it will be soon after the motor swaps done. well anybody know anything on either of the adapter kits let me know i havent decided on either one yet. except ones cheaper.
Northwest Offroad adapter kit
http://www.northwestoffroad.com/part...cadapters.html
Advance Adapters kit
http://72.20.96.178/commerce/ccpc109...00-50-4400.htm
Old 10-08-2007, 09:54 AM
  #27
roundhouse's Avatar
Originally Posted by jmcbmx
if anybody has any good links for a 5.0 swap please post them up. i am trying to gather as much info as possible before i start digging in.
www.fordfuelinjection.com
also
www.classicbroncos.com
has a lot of info.
I think the R trans would be ok.
Isnt that what the people who swap in the Lexus V-8 use?
I wouldnt go backwards to a 3 speed, unless its just a trailtruck, losing the OD would kill the mpg.
Old 10-18-2007, 06:56 PM
  #28
jmcbmx's Avatar
well my adapter from advance came in wedsday and my shifter came in today it is an Art Carr shifter from Wild Horses Four Wheel Drive
got my 4.7 reduction gears installed
the engine bay is empty will be hopefully more empty after i get the charcoal canister and some other odds and ends out
I dropped off my c4 and adapter at the tranny shop today. Gonna have them go thru it, maybe rebuild it, install a shift kit, and bump the stall up a little bit.
Oh yeah i picked up some paint the other day too its gonna look sick with this ...
its the real deal...
i have most of the interior pulled out so i can cut out the tunnel to do the bellytuck. the goal is to have the t-case completely above the frame rails but we'll see how that goes once i get it in and mached up.
there it sits for the night...
this weekend i'll be ordering the solid axle kit and picking up my front axle.
And by the way these tires are for sale. 33x12.50/15 TrXus M/T 95% + tread a few knicks in the sidewalls from where they rubbed on the body but i would like to get $550 outta them .
Old 10-18-2007, 07:00 PM
  #29
Tacoma750's Avatar
sweet!
Old 10-18-2007, 07:24 PM
  #30
95ToyotaPU007's Avatar
good luck man. Its going to be sweet. I too am tired of hearing about the 3.4 swap. Nice to see a toyota with some muscle under the hood.
Old 10-18-2007, 07:58 PM
  #31
fillsrunner4's Avatar
Looks good cant wait to see that motor in there. What kind of lift and axles you gonna use with that power?
Old 10-18-2007, 08:25 PM
  #32
Tacoma750's Avatar
That tranny will hold up well. keep up with your maitnence. I run it behind a buick grand national motor with no problems..and i have two friends that run it behind chevy 350s.
Old 10-19-2007, 08:27 AM
  #33
n4ynu1010's Avatar
Pics , ford motor in Yota (crying)
Old 10-19-2007, 09:02 AM
  #34
idayota's Avatar
i dig the project...cant wait to see the motor sitting in the engine compartment. about 15 years ago when we put a ford 3.8 v6 into a cj2a we used a c6 torque converter. the guy at the tranny shop said it would hold up better for wheeling. just some thoughts...
Old 10-19-2007, 10:03 AM
  #35
n4ynu1010's Avatar
Runner with rocket boosters and wing tips
Old 10-19-2007, 10:26 AM
  #36
Alex 400's Avatar
a 3.8 with a c-6? never going to break that transmission. they put the c-6 behind every big block or early diesel in ford pickups.
I think a c-4 would be better because it is lighter than the c-6 and they would really be pretty good behind a 302 and in a light toyota
Old 10-19-2007, 10:46 AM
  #37
apalmer1's Avatar
Definately id go with R150/R150F, then id keep the 22re T-case since it has a reputation as being the strongest.
Old 10-19-2007, 10:59 AM
  #38
idayota's Avatar
sorry, i didnt finish my thought... it was a c-4 tranny with a c-6 torque converter...hope that makes more sense.
Old 10-19-2007, 11:34 AM
  #39
DudeBud's Avatar
nice choice for a motor
Old 10-25-2007, 06:29 PM
  #40
jmcbmx's Avatar
tranny shop called today its done 830 dollars later..... its rebuilt, adapter installed, low stall converter, and a shift kit. pickin it up tomarrow. then prolly on hold for a few weeks till i get some money banked up to get the straight axle kit, the tranny was a little pricey. i think i'm gonna do the SAS befor i put the motor in so its easier to do both install the motor and sas. I stripped the inside of the cab the other day and installed some dynamat on the roof and back part of the cab. hopefully it quiets the rumble of the v8 power down a little bit. so it dosent sound like ur riding in a coffee can. after that i did some painting with the Olive drab paint and i gotta say it looks pretty sick. i cant wait for the whole truck to look that good, i'll post some pics tomarrow.
Quick Reply: 302 swap is about to go down!
