2nd-gen harmonic balancer tools
Old 01-22-2007, 12:09 PM
brjason's Avatar
Hi,
I just realized a couple of days ago that I'm going to need a special tool to hold the harmonic balancer while I bring the crankshaft bolt to torque specs.
The FSM for my '92 4Runner lists SSTs 09213-58011 and 09330-00021 as the tools I need. I've figured out that #09330-00021 is the generic handle ("companion flange tool") that attaches to various engine-specific ring-shaped tools, and that #09213-58011 must refer to the ring-shaped piece I need.
I've called SPX/OTC about these... they'll be able to ship the handle at the end of February , which sucks, but what is worse is that the SST# for the ring-shaped piece doesn't show up as valid in their systems at all (and they aren't able to look a tool up by description...).
Does anybody have an updated SST# for this tool for the 3VZ-E? Any other ideas about how I can track this information (or the tool itself!) down?
Thanks,
Jason
Old 01-22-2007, 10:15 PM
Ebin's Avatar
NAPA's got one for $51.00
Old 01-22-2007, 10:20 PM
brjason's Avatar
That would be awesome... do you have a part # or a link or anything? All I've seen there are pullers for the harmonic balancer, but if they have a tool for installing them that would be really sweet.
Jason
Old 01-23-2007, 04:23 AM
maxpower_hd's Avatar
You should be able to get it pretty tight with an impact gun, then use the torque wrench after it's installed in the truck. That's what I did and it worked fine. No special tools required. The driveline held it easily. It seems that removing it is the difficult part, not replacing it.
Old 01-23-2007, 06:04 AM
brjason's Avatar
Awesome, thanks... I'll see if that works. I like the sounds of it...
Jason
Old 01-23-2007, 06:27 AM
mt_goat's Avatar
I hear that works with a manual (tranny in 5th gear & wheels blocked) but if you have an auto it doesn't. BTW the torque spec for the crankshaft pulley bolt is 181 ft-lbs for the 3VZ-E and you don't want that to loosen up down the road.
Old 01-23-2007, 07:30 AM
The 22RE has the same torque spec and mine was a manual. I would have to think it would still work with an auto though. It's still only 180 pounds. BTW, mine was in 1st with the ebrake on and no chocks on a smooth garage floor and it didn't even try to budge.
Old 01-23-2007, 07:39 AM
brjason's Avatar
Yet another reason to not buy an automatic...
Old 01-23-2007, 07:49 AM
mt_goat's Avatar
So is that what you have? You never said.
Old 01-23-2007, 07:51 AM
brjason's Avatar
Oops, sorry... no, I have an MT. Whether or not this technique would work on an automatic, I fully expect it should work fine for my needs.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
RobotMoose
02-22-2020 07:44 AM
Scottcrb
03-03-2016 11:57 AM
Kytowboater
09-17-2015 11:17 AM
Streetrod19772000
09-10-2015 06:22 PM
Quick Reply: 2nd-gen harmonic balancer tools
