1987 Pickup with Dual timing chain
Old 08-02-2015, 02:12 PM
Isakdmunky's Avatar
So I have an 87 pickup with a dual timing chain, but my head is cracked. I need a new one, but all the ones I've been able to find for my engine are single timing chain heads. Can someone help me out?
Old 08-03-2015, 04:31 PM
donomite49's Avatar
Aftermarket dual chain conversion?
Old 10-19-2015, 11:50 PM
-City Slicker's Avatar
is it worth it to have a dual timing chain?
I'm redoing mine right now (single) and I've thought about the mod.
it just seems like it would be an extra thing that could fail..
they might or might not have re-engineered the engine for a reason?
Old 10-20-2015, 04:45 AM
rondogracing's Avatar
I didn't know they had duel chains is it the V-6 Engine?
Old 10-20-2015, 09:35 PM
donomite49's Avatar
Dual chains are way more durable
Old 10-21-2015, 05:14 AM
Dale Johnston's Avatar
Location: Strafford Missouri, right outside of Springfield
Is there enough room in the stock timing chain cover for dual chains? Do you have any pics? This sounds interesting. If you wanted to go back to single chain could you replace the lower sprocket?
Old 10-21-2015, 11:16 PM
wyoming9's Avatar
Red face
Quite possible at some time the a pre 84 engine was installed and through the owners that fact was lost.
Now if this engine put out 300 hp plus I could see the advantage to a dual row chain but stock.
But this is just me.
Old 10-21-2015, 11:19 PM
the_supernerd's Avatar
Either you have an older 22R that someone put in there, or an aftermarket timing chain conversion kit. I think there are a few companies that sold dual row conversions for the newer 22Rs. If it is a conversion, then you should just be able to put a new head on it and re-use the old conversion parts. If it is the older 22R, you need an older 22R head, or a 20R head can be used for more horsepower.
junder28
25
06-21-2016 06:24 PM
shisha1999
09-21-2015 08:22 PM
Sidherish
08-02-2015 01:42 PM
Dakotaneu
07-27-2015 12:03 AM
Quick Reply: 1987 Pickup with Dual timing chain
