Where to put grey sealer on timing cover?
Should I put grey sealer on the block side of TC gasket and the TC side? How about the water pump gasket? Both sides? I tried searching here but did not find this info.
Book says to dry fit them. But personally I put a dab at each bolt hole to keep a gasket from sliding around too much. Definately put some on the flange and upper section of the single bolt from the head to the TC under the distributor cam, that puddle is just a leak waiting to happen.
Learn something new every day.
Badger62811
06-26-2015 09:26 PM
