Right hub staying Locked!!!
Old 01-26-2008, 09:24 AM
jagger_snitt's Avatar
Well I'm still working the bugs out of my 87' 4runner(sas'ed)
The right hub is staying locked in. Wheither the selector is on free or lock it stays locked. What could cause this? I'm still learning about the Solid front axle so any tips or advice would be apreciated. I have to replace my knuckle bearings here in a few days so I'd like to fix this while I'm at it.
Thanks!
Old 01-26-2008, 09:27 AM
TrikeKid's Avatar
Manual or Auto hubs? Have you tried backing up to unlock it?
Old 01-26-2008, 09:28 AM
toytech76's Avatar
I think your right hub may be bad internally. Replace them with some good used factory hubs and you should be ok
Old 01-26-2008, 10:31 AM
4Crawler's Avatar
Pull the hub off and clean/rebuild it. Likely has some dirt or too much grease inside making the locking gear stick or was assembled improperly:
http://www.4x4wire.com/toyota/mainte...d/hub_rebuild/
Old 01-26-2008, 10:49 AM
Thanks. Manual Hubs by the way. I figured that it needed rebuilt... but not positive...
Old 01-26-2008, 12:42 PM
waskillywabbit's Avatar
X2
carlspeed
08-23-2015 02:59 PM
Athansinis
07-27-2015 08:38 AM
Steven.m.paulk
07-24-2015 01:44 PM
PlayAwhile
07-20-2015 11:36 AM
Steven.m.paulk
07-13-2015 01:40 PM
Quick Reply: Right hub staying Locked!!!
