Does an 84 22r have a knock sensor
Tried searching but couldn't find a direct answer, does an 84 22r carbed truck have a knock senor. The reason I'm asking is because I dicovered yeasterday that mine had one, its not plugged in or anything but it is there and I thought only 22 re's had them. The P.O. put another motor in it before I bought it, said it came out of a 85 4runner just wondering if it was a 22re block .
A carbureted 22R does not have a knock sensor. The timing is mechanical. If your engine has a carburetor and there is a wire going to the knock sensor, then it does not belong there and you should figure out what the wire is suppose to go to.
rjtrials
08-06-2015 07:25 PM
