Crossmember and transfer case mount not lining up
I just replaced the W56 in my 85 runner, and now the hole in the middle of the crossmember will not line up with the hole on the bottom on the transfer case mount. The only thing I can think of it is to replace the mount, and/or get a new crossmember. Any thoughts?
was it a direct swap? Like you had a 56 before and swapped with another? Is your xmember going the right direction? (dumb question i know)...Are you using the tcase mount that mounts to the xmember from the old set up or from the one you got your new trans from? Might check to see that they are the same. Sometimes they are different.
mYnAmEiSmUd
07-20-2015 06:48 AM
WTB[PacNorWest]: w56 c manual trans with t-case and drivelin
89hilux1
07-19-2015 01:32 AM
crashburnoveride
07-10-2015 06:39 AM
