22RE throttle body (?)
The throttle body on my 85' has worn throttle shaft bores (bushings?) causing it to not come down in idle speed unless you "blip" the throttle. This is causing issues (along with a bad cat) with the smog guys. I looked at getting a used one but, at about $150 and maybe no better than mine, I've been hesitant to go that route. Is there a way to rebush these things, is there a kit available? The price of a new one is through the roof and I can't even find rebuilts. I have about 330,000 miles on it (the throttle body, not the motor) and the cat as well (I guess it was due for replacement) Any help is appreciated. Thanks!----------Hans
Check out www.nix99.com , ask for Josh, see what he can do for you. Tell him your a member here, it might get you a better deal.
06-01-2021 01:51 PM
montanatruck
02-26-2017 07:07 AM
