removing brackets from solid axles
1983 front and rear axles. I'm going to do high steer and a u-bolt flip. Which brackets can I torch off?
I already cut the e-brake brackets off the rear axle (going with t-case e-brake). The front axle has a gusset already on the bottom of the axle (driver side) do I remove that, or leave it and get another to weld on the top?
Thanks
Thanks
Thanks
Thanks
I hope the housings are not that thin. I have some rust on one side where the u-bolts were. I'll clean it up and have a look. I need to drag the axles to work to get the rims off (no air tools at my house).
They're not on that tight, just rusted really bad. I broke one while doing it at my house. I got all the front nuts off at my house. The rears I had to fight with a 3ft breaker bar to get them to budge. My 1/2" impact made quick work of them, didn't break one.
Now I need to get my 4 jackstands back from the kid who borrowed them so I can start to clean these things up.
I sprayed the lugnuts with PB Blaster the day the truck rolled into my yard (3 weeks ago) and been spraying them every so often.
I was looking at the e-brake from http://www.allprooffroad.com/
1) Will your knuckle gusset kit interfere with the u-bolt flip? It looks like the shock mount might be too long.
2) Are the leaf springs (4" or 5") normal lenght? I do not want to relocate my hangers.
Thanks.
2. You will not get the noted amount of lift without moving hangers out as the lift leaf springs are longer, so if you left them as is you would be much higher if it worked at all.
Off the top of my head:
Procomp
Downey
Trailgear
Marlin
Tuff Country
Rough Country
Trail Master
North West Offroad
Superlift
All make Springs for the 79-85's. I have a Procomp 4" setup that I bought used, it included Shocks, Brake hose relocation brackets and a drop drag link they seem alright but I dont think they are going to handle the trails I plan on taking them on and the shocks are iffy, Never really liked Procomp but it was just an impulse buy, cheap setup, if it breaks it breaks no big loss for me.
Same here, i bought procomp springs cause they were at the store and i didnt want to wait for the mail to come with my trail gear stuff. I set it all up and now i am replacing with my trail gear stuff. my loss, i will be selling them soon.
Flying91
45
04-11-2024 04:39 PM
scottyg486
07-19-2015 05:34 PM
