80' yota Truck: No tail lights, where to start...
Hi all, I have a 1980 Yota RV and the tail lights arent working, just looking for a general direction to get started in, the rear half (RV end) is connected at a clip at the end of the cab. There is no power at that clip so it is in the cab.
Thanks in advance!
Ty
Thanks in advance!
Ty
Best place to start is the fuse.
See if you have battery voltage to that point
Then you will have a starting place . then just work from plug to plug
Do the dash lights and front marker lights work??
Corroded plug where the rear harness plugs in .. Have you done anything that may have cut the harness ??
Bad ground Bad bulbs .
Have you tested that the lights work and have figured out it is a wiring fault
Does this thing have Toyota lights or some after market lights from the body builder??
09-04-2015 09:27 AM
WTB[PacNorWest]: WTB Factory chrome fender trims 4x4
skebe22RTE
07-31-2015 02:03 PM
PopsDad1
07-30-2015 02:21 PM
sabine
07-18-2015 03:59 PM
Johntom240
7
07-13-2015 12:18 AM
