Tempe AZ: 1969 Toyota 4X4 FJ55 LAND CRUISER PORTAL AXLED ROCK CRAWLER
#28
Happy new year to u as well, man!
I guess it is not a shock, considering its a major cabbage drop... , but honestly? I cant beleive this thing is still on the market
BUMP! .....SOMEONE grab this and get it up the mountains! I would really like to live vicariously through whomever grabs it! Lol
Best wishes, Sir!
Best wishes, Sir!
#34
MOAB VIDEO http://www.youtube.com/watch?v=4UYI2...ature=youtu.be
RECENT PICS IN MY DRIVEWAY http://69fj55sale.shutterfly.com/
ENGINE
- 1972 Chevy 350 (360 CID) 4 bolt main / 010 block castings
- Blueprinted, .060 over on bore, decked, line honed, detailed and balanced
- 1988 late model truck heads - .194 intake / .160 exhaust w/ Dynagear stainless valves, Pioneer springs & retainers
- Heads - chambered, polished, bowl ported, milled to approx. 68cc
- Elgin Cam #E-1127-P, Intake .387 lift, 258 deg duration, 108 deg lobe center / Exhaust .410 lift, 273 deg duration, 116 deg lobe center
- HP hydraulic lifters, #HL-1817
- Dynagear Double roller timing chain
- Federal Mogul cam, rod, main bearings / Sealed Power piston rings, moly top ring
- Chromoly push rods
- Mallory Comp 9000 ignition w/ Hyfire photo cell
- Edelbrock intake with Rochester Quadrajet carb, manual underdash throttle control
- Dual fuel pumps, stock mechanical & Carter 8 psi electric (2 spare electric pumps onboard)
- Chevy steel crankshaft, .010
- Pink connecting rods (forged/profiled) with ARP bolts magged and polished
-TRW flat top pistons, 9.5 to 1 compression ratio
- 5 bolt big block oil pump and pickup
- 5 qt oil pan with Truefilter reusable oil filter
- Dynamax Block Huggers headers w/ 2-1/4" triple chamber flowmaster mufflers
TRANSFER CASES
- First Case - 1982-'85 FJ60 2.28 low gear
- Second Case - 1970-1980 GM NP203 Fulltime 2.0 low gear
DIFFERENTIALS / AXLES
- 63.5" wide wheel mounting surfaces OD
- both differentials are FJ60 rear high pinion diffs 4.11:1 gearing, 27 spline pinions, (spare third member included with LockRight)
- Detroit Locker rear, ARB Locker front
- Axle shafts are stock FJ60 Toyota 30 spline, resplined on outer end to Humvee 97.5 & later 34 spline inner, 27 spline CV outer axles, heat treated (spare CV joint and long side shaft)
- Humvee halfshaft outer assembly 97.5 & later (20% larger and stronger) NAPA #7897, 7898 or 7899 NCV
- Dutchman Motorsports hybrid Humvee steering portal to LC axle housing
- Humvee steering portal boxes (4) 1.92:1 gear reduction
- Speedway motors double axle seal 2.5" OD (part # 919-0951 spare included)
- Driveshafts are interchangeable front to rear, spare driveshaft
TRANSMISSION
- GM TH-350C (Filter B&M 10288) rebuilt with B&M, TCI and Transgo parts
- B&M Torque Converter, 1900 rpm stall, manual lockup switch
- trans cooler
- B&M sport shifter
COOLING
- Modine #347 (1967 Buick Skylark 5.7L) 4-core cross-flow radiator, modified 2" wider with high efficiency core
- Electric puller fan and shroud, Flex-A-Lite Black Magic XTreme 180 at 3300 cfm with 18 amp draw
- 190 degree Stant high flow thermostat
- Flow Kooler long neck, high volume water pump - Summit part #1759
ELECTRICAL
- 140 amp Powermaster 12SI style alternator, Summit #PWM-57294
- Autometer UltraLite Series Gauges: 5" Speedo #4489, Tach 3 3/8" #4497, Oil #4321 (mech.), Water #4332 (mech.), Fuel #4316, Volt #4391
Fuel Sender #3262 (240 ohm empty, 33 ohm full), Speedo Sender # 5291 (16 pulses per revolution), all in custom SS dash
- Painless electrical wiring harness conversion
- Mobi-Arc 200x onboard welder
- 750 watt onboard 110v AC Inverter
-150 amp circuit breaker for inverter
- Dual Optima batteries in custom boxes
- Warn XD9000 Winch with nylon rope
- LED tail lights and flasher, LED amber turn signals
STEERING
- Dual-rod hydraulic steering cylinder - 2.5" bore, 1.5" rod, 7" stroke, #6 port - Front
- Danfoss return to center (load reactive) orbital control valve - 3.25 turns lock-to-lock
- PSC Remote reservoir 1400 P style pump - 1,650 psi, 5+ gallons per minute
- Borgeson custom "double D" steering shaft (1" 48-spline column / 3/4" 36-spline) 36" long
- Dual-rod hydraulic steering cylinder - 2.5" bore, 1.5" rod, 4 1/2" stroke, #6 port - Rear, with quick mount ABS lockout sleeves
- Spidertrax steering links and rod ends
- Humvee portal high steer steering arms - Right part #5591279, Left part #5591280 (Stazworks)
- Chevy tilt steering column conversion
- spare hydraulic connectors and line, spare steering link rods
SUSPENSION
- front and rear both custom Triangulated Ball/Link suspension with built in anti-wrap trussing
- Front - Rancho RS 9000X shocks - (RS99034) 20.125" collapsed, 34" extended, 13.875" stroke
- Rear - Rancho RS 9000X shocks - (RS99116) 15" collapsed, 23.75" extended length, 8.75" stroke
- Air Bags - Firestone 1T14C-7 Reversible Sleeve (part no. 5426, spare bag included)
- Air Valves, manual, 3 position/4 way - Parker HVN4400-10 (3/8" port)
- Humvee Heavy Duty upper ball joint w/ 3/8" retaining bolts - Part# 260-1461 (Napa)
- Humvee Heavy Duty lower ball joint w/ 7/16" retaining bolts - Part# 260-1462 (Napa)
BRAKES
- Center mounted 10" X 7/16" machined rotor behind last transfer case
- '99 Cadillac Eldorado caliper (Napa - Caliper kit #1759, Napa - Brake hardware #83101), extra set of pads included
COMPRESSED AIR SUPPLY
- Caterpillar 3208 Tu Flow 501 air compressor - max pressure 130 psi, 100% duty cycle, 12 CFM at 1,250 rpm
- Front Bumper tank - 1.6 gallons, Rear tanks - 3 gallons & 5.67 gallons, with female quick disconnect air hose fittings at front and rear bumpers
- spare air connectors and line
MISC SPECS
- Vehicle weight = 5000 lbs
- Front Axle Weight = 2,400 lbs, Rear Axle Weight = 2,600 lbs
- Tilt up side = 2,100 lbs, Tilt down side = 2,960 lbs
- Rocker Panel Clearance, Low = 2' 3" High = 3' 6" (15" Height Adjustment via Air Bags)
- Minimum ground clearance = 17"
- Approach Angle, deflated = 85 degrees inflated = 82 degrees
- Departure Angle, deflated = 73 degrees inflated = 72 degrees
- Maximum Tilt Angle = 25 degrees
- Breakover angle = 37 degrees
- Steering (turn-to-turn) - 30 degrees - front
- Steering (turn-to-turn) - 20 degrees - rear
- Axle Ratio - 7.89:1 (4.11 diff x 1.92 portal gearing)
- Final off-idle low gearing ratio - 270:1 (7.89 axle x 2.28 first TC x 2.0 second TC x 7.5 trans first gear off-idle)
ENGINE
TRANSFER CASES
TRANSMISSION
- trans cooler
- B&M sport shifter
COOLING
ELECTRICAL
STEERING
SUSPENSION
BRAKES
MISC SPECS
6th Gear
19
12-10-2019 07:31 AM
PureTacoma_Tundra
PureTacoma_Tundra
06-29-2015 09:45 AM
Crazy_Guy97
12
06-24-2015 04:02 PM
Corey
06-16-2002 08:43 PM
