CBI fabrications Tire Mount/ Bumper
Ok, I've been threatening to do this for a while. I purchased my bumper and carrier from Steve (owner/operator CBI fabrications). Before I placed the order I played 20 questions with Steve, "how much, how long, what materials, maybe next month. yada yada yada" He was very patient, even sending me a few in-progress pictures to tease me. His customer service was excellent and he delivered faster than promised at a great price. Now I could have gone with a swing away carrier, but with the cleance I have I can stuff my 33" underneath if needed, so I went with the removable swing down carrier. When it arrived, all it needed was a rub down, paint and install. Install on the bumper was an Joy, It fit better than if even Toyota had made it, perfectly square to the frame and level, not to mention solid and well built. The carrier required minor modifications (to suit me) after painting and assembly I installed the all-thread and lock nut, I quickly found the lock nut was too thick to tighten down the wheel. I threw it (nut) in the vise and cut it in half with a hack-saw (about 2 minutes) with the new thinner nut the speed nut worked flawlessley. I also added a liberal dose of loctite to the threads. Now how to secure the tire, I simply drilled through the end of the all thread in 2 stages to make a hole large enough for a pad-lock. Wiring for the liscence plate light (included) was easy as well, I simply tapped into the harness for my trailer lights. Now 4k miles later, I am very pleased and still have no movement in the Carrier. Thank You Steve, Good job!
http://www.cbioffroadfab.com/
Raw Bumper
painted carrier
stabilizing bolt in the reciever hitch that stops wiggle
installed bumper
Raw Bumper
painted carrier
installed bumper
Originally Posted by r0cky
I just assembled mine and got everything to work today! (except for the huge nut on the huge bolt which won't thread)
I like it, but have some questions/observations (sorry if all of this has been answered somewhere else - I just stumbled on this thread)
you lose the use of the receiver hitch to tow, unless you remove the tire carrier? is there an option to have both (your cake and eat it too)?
how is visibility out the rear?
can you order custom add-ons to the bumper prior to manufacture - such as tabs for aux. backup lights, antenna mounts, etc?
tia
tia
tia
tia
1) swing away carrier (much more $$)
2) tire inside cargo area
3) roof rack mount
4) stock location
5) no spare
Visibilty is somewhat limited, but not unbearable (use your side mirrors)
Add ons, ask Steve his name is CBIguy here on yotatech or contact him through http://www.cbioffroadfab.com/ . I bet he could do about anything. Also as far as I know he builds them for you, not a "stocked" item so expect a couple weeks!
