Are you computer savy?
I once had a USB card that had issues. On a mac you have to eject things like cameras and cards, like you would a disk or stop a drive on a PC. If you eject it, it leaves the desktop and then you can remove it.
I once had a USB card that I would eject it, and it would disappear off the desktop, then reappear before I could remove it...which is a no-no. Turned out the aftermarket card had a short or some issue. Once I removed it, everything worked fine. Replaced the card...they are cheap, and it solved the problem.
I also have one card reader (USB) that does the same thing you are describing. You put a card in, the light comes on, and nothing happens...funny thing, it only happens with SD cards, not compact flash or smart media. USB things are just fickle sometimes. Have you tried the Camera on another computer?
Before telling me to "lay off" maybe you should read my whole post! I did give some suggestions on card readers, and part of the issue is probably system related. Windows is not as stable as the Mac OS, and MACS are much better at peripheral compatability since they don't need "Drivers". I have 12 PC's at my business and two Macs, the PC's have problems and compatability issues every day, the only issue I have had with my macs is a battery issue on my laptop. While it may not be the anwer he was looking for, and was partly meant as a joke (all these PC issues crack me up), it would most likely make his photography life easier.
By the way I believe it is LINUX....
Whether it is a joke or not you are still being elitist and your only retort to attack my dyslexic typing only goes to prove your own guilt. I have built machines with just about every OS there is and right now I'm sitting in front of 3 machines with a total of 5 OS's including MAC X. I am intimately familiar with the troubles all of them have and were someone to come to me asking what system they should buy given that users requirements and computer knowledge I might just recommend a MAC provided it fit the user. But I don't bring bias to a conversation when someone asks a specific question about a PC. It simply is not constructive and there is no need for it.
As Midiwall stated this is not a Mac vs. PC issue and if you read my post, you will notice that I agreed with him. Later in the thread the poster stated "I hate Macs" (you notice I never said I hate PC's), and as for what I said about him "not liking computers", I was simply agreeing with what he said. It's all good!
That said, windows xp is very fickle, and that was my point (whether I stated it well or not)! I run it on two machines at my office, and they are the main ones we have issues with. I said nothing about "Macs only", but in this situation...they are generally more compatible. Sorry for attacking your spelling.
back on topic: I would try a card reader. Also try plugging the camera into a mac, ahhh, another computer, (jk) If it works fine on another computer the camera is not the culprit. I would guess Windows is getting confused, or maybe motherboard or USB board issues. Do you have any other peripherals plugged into the same USB card/hub that the camera is plugged into? Are you using a USB hub, maybe that is going bad?
Also check your camera's settings, maybe they got changed somehow. There are usually two options for connectivity on digital cameras, PTP and mass storage, make sure it is set on mass storage.
#25
What I have basically said, but better!
kawazx636
10-06-2021 03:03 PM
some drunk guy
08-03-2021 06:09 PM
