| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
I Hate Wireless Routers
#2 (permalink) | |
Quote:
#3 (permalink) |
i have a linksys and have the same problem as oly.
i miss being wired.
__________________
[2002 4Runner 4WD] |
#4 (permalink) |
hmm..thats wierd. your dl continues but you get kicked off the internet? doesnt add up. If you lose connection you should lose the dl unless it saves where it last cut off. Mabye you could get a booster?
#5 (permalink) |
Since it's being "picky", i'd say it's more likely a problem with your computer rather than the router. Do virus and spyware scans exhaustively, then we'll go from there.
__________________
-Chris If you can't explain it simply, you don't understand it well enough. Click here to search! My Website |
#6 (permalink) |
is your signal at full strength? are you using a usb wireless reciever or one in the PCI slot?
#7 (permalink) | |
Quote:
Chris, I've reset every thing on my comp. The only other thing I can do is reinstall windows. So, I really don't know what the problem is. The thing that gets me is that it's very intermittent. It'll go for a day or so, the do this every 3 mins. |
#8 (permalink) |
I recently replaced my linksys with a SMC. Night and day difference on the range connection. Linksys is overvalued junk imo.
The smc just works, the linksys had to be reset every so often or I had no connection at all. But then again, SMC used to build the better arcnet network cards in the late eighties. They've been around for a while. I guess when routers bugger up, there isn't a whole lot we can do except replace it.
__________________
2006 4Runner V8 Sports Edition Red 1997 4Runner 3.4L Bushwacker Flares, 5spd, E locker |
#9 (permalink) |
Senior Member
Have you guys upped the firmware on your wireless AP/routers?
__________________
98 Limited 4x4, Rockstomper skid, Rockware Front bumper, Warn HS9500i, 1" RB BL, Tundra coils front & OME HD rear, Nuke quick discos, diff drop'd, 305/70/16 Baja Claws, Electric Locker, couple of battle scars, but nothing major :) |
#10 (permalink) |
First thing I usually do.
__________________
#11 (permalink) |
I have a linksys and have the same problem as you guys, its really startin to tick me off...
__________________
92 pickup... sold 90 integra- b18b turbo, intercooled, 10 lbs of boost, 240 whp... blown up 79 2wd yota pickup |
#12 (permalink) |
I would upgrade the firmware too, as the next step.
If that doesn't work, try bypassing the router for a day or two and see what happens. If the problems "disappear", look into another router. I've used D-Link stuff for years with zero problems. Kicker is, I got both my routers for $20 each, after rebates.
__________________
#13 (permalink) |
Senior Member
I just purchased a D-Link wireless AP and it rocks...
__________________
#14 (permalink) | |
Quote:
__________________
#15 (permalink) |
Never had any problems at all with the Airports other than a few capacitor problems on the early graphites. They seem to work very well with both Apple airport cards and PC notebook adapters. JMO
__________________
94 4Runner 4x4, V6 Auto, Outlaw II's with BFG 33x12.5x15 on stock suspension (no lift), Kenwood KDC-MVP Sirius/MP3 player, Bushwacker extenda-flares, 1700 watt power inverter, Air intake mod, Radio Shack CB, GPS, Swing arm tire carrier, modified 1st gen Toyota 4Runner Rollbar, Aisin manual hubs, 87 inclinometer, Toyota Brush guard. Where ever you go, there you are. I started out with nothing & still have most of it left. |
#16 (permalink) |
smc routers work worth crap, linksys are hit any miss, and dlinks are by far the most rocksolid of any router I've had.. and it only cost me $15. oh, and I wouldn't touch hawking tech with a 10' pole.
__________________
1991 4Runner SR5 3.0L 4wd 5Spd, 31x10.5 ATs, HG replaced 02/05, 320,000km 2008 Acura CSX 2.0L 5Spd, Leather, Sunroof, Wing, Fog Lights, VSA, TC, 10,000km |
#17 (permalink) |
My Linksys stuff has been great. I migrated to Netgear for an integrated wireless/router, but had the problem with dropping connections. I got so frustrated that I went back to Linksys with a separate router and separate wireless access point. Easy to pinpoint a problem this way.
__________________
UZswap.com A site dedicated to sharing info for swapping the Toyota/ Lexus UZ (V8) engines into Toyota Trucks and 4Runners. My 4Runner 1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys, low lift, hacked fenders, tubbed firewall, custom armor TOOLandFAB.com A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion |
#18 (permalink) |
I had a Linksys wireless hub that worked great for years, then it got slower and slower, but never really died. I replaced it with a Netgear wireless hub which constantly dropped the connection - but did so across the board. Downloads, email, everything. Once I upgraded the firmware, I had no more problems and it works fine.
__________________
Steve 1995 4Runner - V6 - 5 Speed Rear ARB, Manual Hubs, Front TruTrac, Marlin Transmission, ARB Front & Sonoran Steel Rear bumpers that have saved my life!! |
#19 (permalink) |
Is this on laptop where the signal gets dropped? If so, you are very likely experiencing the power management problem. Intel has a TSB about it. There seems to be a bug in the way that Intel implemented power management in some chipsets and it mistakenly detects a lack activity and puts the wireless card to sleep, even though it is in use. 99% of the time, disabling the power management feature of the wireless card solves the problem.
I have been suffering with dropped wireless connections for the past couple of months, with exaclty the same symptoms you describe. Some days it was worse than others. I spent a week or so exploring possible solutions and finally stumbled upon some info about the power management problem. A quick fix and I haven't been dropped since
__________________
-Rob Slightly Modified 2001 Tacoma - WATRD.COM WATTORA is becoming NWToys! Tread Lightly! certified Tread Trainer Search 100+ Toyota tech sites, including this one: Toyota Tech Search |
#20 (permalink) |
I have d-link also and have not had any problems since set up.
__________________
92 4Runner SR5 V6 4X4 Skyjacker Nitro shocks, Pro-Comp steering stabilizer, clear bumper lenses, lund windjammer, OME standard coils, ISR mod, inlet pipe removed, Bushwaker Fender Flares. 2002 Tacoma Prerunner V6 Xtracab. Lund Intercepter bug guard, rear glass sunshield, Bilstein shocks on rear. 2004 Honda CRV EX stock belongs to wife. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Can not access my Linksys routers page | Corey | Computer Talk | 11 | 05-01-2006 12:29 AM |
| Tell me about routers - for wood, that is | TDiddy | Off Topic Talk | 3 | 10-15-2004 11:44 AM |
| tell me about routers | Robinhood150 | Computer Talk | 16 | 09-01-2004 05:09 PM |
| I need to go wireless.......Help. | GRNTACO | Off Topic Talk | 9 | 05-18-2004 05:01 PM |
| Shame on Belkin routers | Corey | Off Topic Talk | 2 | 11-09-2003 06:52 PM |
