Which Noise Filter?
#42
This probably won't be the full solution to all of your problems, but here's my shot at your problem. First, and this will sound crazy, but take a good old roll of aluminum foil and start wrapping all of your plug wires with it. Make sure that all the foil is connected to a good ground. Be careful, as a charge may build up on the foil if you don't ground well enough.
After you've covered them all in foil, try your radio out again. If you see a significant difference, you will want to find some "EMI shielding tape" as a more permanent solution. I'm not sure where the best place to find this would be, but Mouser.com will probably have it. I believe 3M is one of the largest manufacturers, but there are probably others. You can probably get someone on the phone from Mouser and have them make a recommendation about a product that is heat, oil, and chemical resistant.
You might also want to find a good braid material and bond all of your doors and trunk to the body. This will help shield out unwanted RF energy from the vehicle as well. Good luck!
#43
Good ideas. Mine seemed to be better on the last trip, but it is still abit noisy, it breaks through the squelch when I'm throttling.
I haven't had the time or resources to get into it.
Let me know how the noise filter works out, Yota4Runner.
crammit442
7
11-29-2017 12:30 PM
Iceman4193
08-28-2015 08:43 PM
