YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > GPS & Communication
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 01-06-2008, 02:05 PM   #1 (permalink)
cb question
k i did a search but i couldn't find what i was looking for. i'm mounting the cb antenna on the passenger side right next to the hood near where the regular radio antenna is. the problem is i cant figure out how to get the antenna wire from the antenna to the cb inside the cab. i want to leave the regular radio antenna there. i can see a rubber seal/gasket thing that has wires going through it into the cab area from the engine bay but i dont know if its ok to cut into it to run the new wire through. im new to this so dont be too hard on me lol. any help is appreciated thanks.
Kno3del is offline
Sponsored Links
To remove this ad, register today!
Old 01-06-2008, 02:14 PM   #2 (permalink)
ozziesironmanoffroad's Avatar
Send a message via AIM to ozziesironmanoffroad
no dont cut into it. thats a grommet, and if you cut into it, every time you go through a puddle, water will come into the cab. take the grommet out, run the wire, then put the grommet back.
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back.
1988 Toyota P/U 4x4
22RE 258,000 miles on original motor
pioneer CD deck
31x10.50x15 BFG A/T
BAJA 100W lights on prerunner bumper
KC Daylighters 100W
rancho rs5000
MUD IS A VALID PAINT JOB!
If not living life to the fullest, why live it?
my trucks official buildup thread
ozziesironmanoffroad is offline
Old 01-06-2008, 02:15 PM   #3 (permalink)
90inworks's Avatar
Send a message via MSN to 90inworks
Remove your corner panel and run it under that and in the front of the door fame. after that run it from your kick panel under the carpet and to your cb. you kind just gotta play around with it there is know right way to instal it.
__________________
FRIENDS: Bail you out of jail and tell you what you did was wrong.
TRUE FRIENDS: Will be sitting next to you saying, Damn...that was fun "
1994 p/u v-6 4x4 ex-cab
Mods,
flowmaster 40 series
cobra cb
tinted windows
alpine 6 button cd player
10in subs
4in susp. lift
3in body lift
35in tires
front locker
Soon to be mods,
tires, wheels, rocker pannels, alarm, Air lockers. :)
90inworks is offline
Old 01-06-2008, 02:16 PM   #4 (permalink)
CJM
CJM's Avatar
Either you run it through the gromet (I pushed mine through it among other wiring) or you run it under the carpet area into the fender area.
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks.
Be polite. Be professional. But, have a plan to kill everyone you meet.
CJM is offline
Old 01-06-2008, 02:16 PM   #5 (permalink)
90inworks's Avatar
or cut a hole in the gasket and run your wires threw it to the right lenghth then get a tube of black gasket sealer and goop it shut
__________________
Mods,
cobra cb
tinted windows
10in subs
4in susp. lift
3in body lift
35in tires
front locker
Soon to be mods,
Old 01-06-2008, 02:18 PM   #6 (permalink)
all these are true, there are some good guys (and gals!) here. and i thought i knew some stuff....
__________________
1988 Toyota P/U 4x4
pioneer CD deck
31x10.50x15 BFG A/T
KC Daylighters 100W
rancho rs5000
Old 01-06-2008, 03:39 PM   #7 (permalink)
ok thanks guys!
Kno3del is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Shifting AT question, a tire question, and what does SR5 mean? Sammer 95.5-2004 Tacomas & 96-2002 4Runners 4 07-24-2005 11:25 PM
Quick Question Regarding Oil Change??? It is not a help question! FlipSide 95.5-2004 Tacomas & 96-2002 4Runners 7 05-15-2004 12:00 PM
20R, 21R, 22R Engine coolant drain plug question (Long read..main question at bottom) love1u0 Maintenance & Repair Archives 5 08-16-2003 02:58 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
