After market radio installation
I took my stock cd/tape radio out of my 98 4runner and need help with weiring the radio. Do i need an adapter for the wiring? and do i need to use the stock amp? there is a 4ch after market amp under the seat and only the right drivers side speaker worked when i had the stock one in the 4runner, so can anyone tell me how to wire all 4 speakers and the two tweeters up to my after market stereo and after market amp? thank you.
ADAM.
ADAM.
need to get a harness like so remove the factory amp and its plug and play thats if the last owner didn't hack up all the wireing to run the wire to that 4ch
http://www.sonicelectronix.com/item_...2B+-+TA02.html
the front tweeters should already have a way to hook them up in the doors, and/or you should already have tweeters IN your doors. Put them in the stock locations so you don't have to hack anything up.
Btw if you bought a 2 way component speaker setup, it will come with a crossover which has one in, and two out (one for the tweeter, one for the woofer)
jasonty
41
12-23-2018 01:00 PM
FS[SouthEast]: 87 toyota pickup 4x4 22r
Yota.Jay
07-26-2015 05:50 PM
WTB[MidAtl]: WTB: 89-95 radio brackets/standard cab carpet 2wd
mtb_taco
07-15-2015 08:36 AM
1998, 4runner, 98, afterfactory, aftermarket, connect, install, installation, limited, market, radio, run, stereo, tweeter, tweeters
