Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
1997 4Runner Sony Stereo Problems
Old 07-15-2014, 05:38 PM
michael33rueckert's Avatar
Originally Posted by drpdmazda
i dont fault you at all for trying. just sometimes a shortcut take a whole lot longer than just doing it correctly from the jump. let me know what happens when you get more time to mess with it, and hopefully you get some good results.
I always encourage people to try it themselves IF they are certain of what they are jumping into. i just had to fix an 05 camry for a guy because his friend who used to be an installer, chopped off his airbag light harness instead of his radio harness, and then went ahead and chopped off the radio harness for good measure. lots of quality time re soldering a new harness in to that car.
Wow I'm glad I didn't do something THAT dumb lol Mine works great for the most part. How could he not see that the harness didn't plug into the original stereo?
Old 08-12-2014, 09:18 AM
is the original system the jbl amplified system? if it is, find the amp which should be a silver metal box right behind the radio area, held in with 2-3 gold 10mm bolts. remove the amp, and on the bottom side there will be a standard toyota stereo wiring harness.
if this is the case, go to your local audio shop and buy a standard toyota wiring harness for non jbl systems. if its a metra brand it will be a 70-1761 you can then wire the radio up correctly and that will hopefully eliminate the issues you are having. if it was a jbl system, and you cut the harness and hard wired straight to it, that will be the cause of most if not all of your problems.
hope that all makes sense
Alright, I finally had time to fix everything up. The factory amp was the root of all evil! Lol Everything sounds amazing now. Thanks for the help! Also, I'm not sure if I already said this but the Sony XPlode speakers do fit in the front doors great.
06-01-2021 01:51 PM
Jnkml
07-06-2015 01:20 PM
karbin
07-05-2015 11:37 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 1997 4Runner Sony Stereo Problems
