What size tubing to use? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > The Fab Shop
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-25-2004, 09:30 AM   #1 (permalink)
Send a message via AIM to ravencr Send a message via Yahoo to ravencr
Hey guys,
I'm wanting to buy some tubing to use for two primary purposes, and I'd like to get by with one 20ft length to save some money. Here's what I'm wanting to use it for:
1) Rear suspension links
2) Skid plate reinforcements
I need something that I can easily use either spidertrax or pro-werks weld in tube adapters for the suspension links, and something that will not dent under most circumstances for the rear suspension links. What do most people use for those? Do they use 3/16" or 1/4" thickness, and what diameter is most common?
Chris
ravencr is offline
Old 03-25-2004, 10:23 AM   #2 (permalink)
loosehead's Avatar
Chris-
I'd say go with 1 1/4" DOM tube with 3/16th inch wall-thickness. This has an I.D. of 7/8", which would let you use the weld-in threaded bungs easily (3/4" threads for 3/4" rod ends).
This would probably be overkill for skidplate reinforcing, though. I would use smaller for this, say 3/4" tube...
__________________
Jayson
1998 4Runner SR5 4WD
V-6, auto, E-locker
loosehead is offline
Old 03-25-2004, 11:39 AM   #3 (permalink)
crash's Avatar
I agree with loosehead, but I would suggest chromo for the lowers, thats how mine is being setup
__________________
STUFF for SALE
crash is offline
Old 03-25-2004, 03:47 PM   #4 (permalink)
Quote:
Originally Posted by loosehead
Chris-
I'm only going to use the tubing for the skid plates in a few places, and you might be right about being overkill for that. So is that a pretty common size then for suspension linkages?
Chris
ravencr is offline
Old 03-25-2004, 03:48 PM   #5 (permalink)
Quote:
Where do you guys recommend getting chromoly tubing from?
Chris
ravencr is offline
Old 03-25-2004, 05:29 PM   #6 (permalink)
Cebby's Avatar
Send a message via AIM to Cebby
Isn't chromo typically thinner wall - ie. dent easily??
__________________
UZswap.com
A site dedicated to sharing info for swapping the Toyota/
Lexus UZ (V8) engines into Toyota Trucks and 4Runners.
My 4Runner
1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys,
low lift, hacked fenders, tubbed firewall, custom armor
TOOLandFAB.com
A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion
Cebby is offline
Old 03-25-2004, 05:36 PM   #7 (permalink)
I have no idea, but I sure would like to know the differences between mild steel and chromoly before I make the plunge.
Chris
ravencr is offline
Old 03-26-2004, 07:20 AM   #8 (permalink)
Shane's Avatar
Send a message via AIM to Shane
Quote:
The fact that it's chromoly has no connection to how thick the wall is. You can get thin wall, thick wall, solid, etc... Heck, a lot of gun barrels these days are chromoly.
__________________
"It's one great big dysfunctional family that now has to split up and spread dysfunctionality around the greater world," Bill Stainton on the breakup of the cast of "Almost Live!"
Shane is offline
Old 03-26-2004, 07:21 AM   #9 (permalink)
crawler#976's Avatar
DOM guide-
http://www.copperweld.com/pdfs/DOMSpecs.pdf
from mild steel to alloy steel- it shows yeild strengths, etc.
later
__________________
...down to the two Taco's, no more SloYota!
crawler#976 is offline
Old 03-26-2004, 04:24 PM   #10 (permalink)
Where can I buy chromoly tubing?
Chris
ravencr is offline
Tags
34, bender, chromoly, cromoly, dimensions, distributor, dom, links, made, road, sanko, size, tech, tube, tubing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
appropriate size tubing die for sliders, bumpers 89-4Runner The Fab Shop 4 12-12-2006 10:14 AM
double cardan shaft tubing size? tech Offroad Tech 1 10-15-2006 07:11 AM
Reccomended size tubing for roll cage? SlightlyModified The Fab Shop 6 07-31-2006 10:39 AM
Tubing size differences... Denk The Fab Shop 10 03-21-2005 02:11 PM
What size exhaust tubing for 3.0? VolcomTacoma 95.5-2004 Tacomas & 96-2002 4Runners 6 01-17-2004 04:20 PM
2009 InternetBrands, Inc.
