| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Solid Axle Swap
__________________
"doing a body lift is like sleeping with a blow up doll, it might make you feel better for now, but it just doesn't feel right in the morning" 1992 4Runner Auto 3.0 135K SASed Free Flow (no cat) Flowmaster 40 exhaust 33x12.5 BFG Mud Terrains Marlin Crawler Rear Bumper All Pro Front Bumper 1984 Front Axle TG SAS kit 4'' w/ bilstein 5150's OME 863 coils ProComp 4" Panhard drop bracket My SAS Thread http://www.yotatech.com/f152/startin...ss-sas-118997/ |
#2 (permalink) |
To help you out this time.... it would probably cost 10k or more if its done right. Its costs most people 5-8k to do it themselves.
Search the forums next time, its been brought up a lot
__________________
Larry '97 4runner limited 4x4 w/ Rear Locker Tcase skid - Frankenstein Front End Suspension - OME Rear Suspension - Lars Discos - ARB Taco Bumper - Stubbs Standard Sliders - Cobra 18 WXSTII Cb w/ 4' Firestick II Antenna - 285/75/16 MT/Rs on 16x8 Rockcrawler 97 series wheels - 1" Roger Brown body lift - Bud Built Front Skidplate and more Project Beast II Webpage Denver Univeristy Off-Road Club |
#3 (permalink) | |
Quote:
__________________
Dan 95 4runner 3vze A/T 84 4runner sr5 Ford 302 T-18 4spd yota t-case yota front and rear both open 37X13.00 boggers 88 4runner 22re 5spd |
#4 (permalink) |
Marlin does the labor for $1400. Do what you can yourself. I'm in the process of an SAS. I just finished rebuilding the axle. I'm having the hangers welded on by a local shop and the driveshaft custom made. The rest is just grinding and wrenching. Lots of details can be found on Pirate4x4.
__________________
Rig Specs '94 4Runner 3.0L V6 4x4, 32" BFG Mud T/A KM, 4" SAS, All-Pro Bumpers and Sliders, Rear Cruiser Coils, Bilstien 5150's all around, Warn M8000, K&N Filtercharger, 300w Power Inverter, Optima Yellow Top, Viair 450C, Cobra 75WXST CB w/ Firestik II, Flowmaster 40 Series, Viper Keyless Entry, Rear-Detroit Soft Locker, Front-Detroit EZ Locker Trail Pics |
#5 (permalink) |
there is a guy on here thats posted within the last day or so selling a whole SAS front end with steering kit and no third for $900
#6 (permalink) |
Check my sig line.
Edit: also check out the price list recently posted: http://yotatech.com/showthread.php?t=61135 He's over $5k just in parts.
__________________
Steve. '93 4Runner V6 Auto 4x4 Robinhood's Lair. || Gettin' Off 4wd Club member Lots for sale:5.29 ARB IFS third member... Click Sierra Club policy: [A reason to close trails] ...Physical soil damage, often readily visible, resulting in: a. Erosion, causing soil loss and damage to stream banks, streams, and fish habitat... Lesson...Stay on the TRAIL! Last edited by Robinhood150; 06-15-2005 at 11:34 PM. |
#7 (permalink) | |
Quote:
__________________
#8 (permalink) |
If you do it yourself, and shop for deals on everything, or buy used, it can be done easily under $3,000 (longs, e-locker or ARB, regear...etc.). Then like someone posted above, Marlin charges $1,400 in labor. I have seen labor for an SAS run anywhere from $300-$2,000.
__________________
1997 Toyota 4Runner, 3.4L (5VZ-FE), 5-Speed (R150F), 4WD, 4.10's, 33's 1998 Toyota 4Runner, 3.4L (5VZ-FE), 5-Speed (R150F), 4WD, 4.10's, 33's 1991 Toyota 4Runner 4 Door, 3.4l (5VZ-FE), 5-Speed (R150F), 4WD, 32's, 4.10's |
#9 (permalink) |
if you live anywhere near NC i'll do it for alot less than the $1400 marlin wants
__________________
Jeremy, 94 4Runner Turbo Leaf Spring SAS front - Coilover 4link rear (starts December) / Supra Swap My Truck is featured on Supracharged.com - Home of the original Supra swap and Forum One of two things will happen, I will die, or the truck will be finished. I'm not sure which will be first. |
#10 (permalink) | |
Quote:
__________________
#11 (permalink) |
By asking that question, I suspect that you don't have the equipment or the know how to do it yourself. I don't know where you live but if you're in CA, you can go to Marlin, He's the best. I think you're looking at around 6K or more. If you want ARB vs lock right, that's gonna make a difference. Some thing to think about also is do you want to do it right the first time or add stuff later. Ex. do it without lockers, diff armors. run with used semiballed tires. ......
__________________
http://www.angelfire.com/ca6/954runner GOD's Country Best Seen In A 4 Runner. SAS front: lf,ARB,Ml4",Marlin arms, rear: cable elock,APlinks,OEmu860,35MT/R 5spd, 4:1. ..."But officer, that was not an illegal turn, it was just an undocumented turn." |
#12 (permalink) |
Its gonna be alot more than $3,000 for sure. I have been looking into this for my 1990 4runner for two years now. I have studied everything and I plan on doing it right the first time. Figure 1500 for the front kit from marlin, 1400 for installation. The rear will probably be 1000 installed with shocks etc. There is so much little stuff you have to remember like brake lines, driveshafts, etc. And, if you are doing an SAS you probably will be running 35"+ tires so gears is another 1,000. I plan on spending about $6000-$7000 and I will be doing the work myself or with friends help. But I am doing f&r ARB's, 5.29's, High pinion front 3rd member, marlin front kit, 63" chevies in the rear and 36" iroks. Good luck.
-Patrick |
#13 (permalink) |
why do you guys spend so much if you are doing the work yourself. gears=1000 learn to set them up yourself, there are plenty of writeups all over the internet. driveline the ifs one should work. I have used them before an have had no problems. the marlin sas hanger kit is less than $200 not including shipping, then you can couse what springs you want to use. im all about saving money and building most everything maybe thats why I think it is cheaper.
__________________
#14 (permalink) | |
Quote:
David
__________________
Buggy in progress - 22RE on pane, A340, 4.7, 8"s, 4Ds 1989 4Runner 3.slow 5spd and big plans... 2005 Ram 2500 4x4 CTD 6spd QC SWB |
#15 (permalink) | |
Quote:
__________________
#16 (permalink) | ||||
Quote:
Quote:
Quote:
Quote:
If you thought all this then I guess you are right, it can be done as cheaply as you say it can by a pro... :pat:
__________________
#17 (permalink) |
whatever you say..... I dont feel like arguing with you.
__________________
#18 (permalink) | |
Quote:
__________________
1987 Mutant 4runner|Slightly Modified|Lacking general build direction -Lifts and Tires look cool at the Mall, Lockers and Gears look cool on the trail. -Internet Nice Guy |
#19 (permalink) |
Fox Fab in Rhode Island wants around $1200 plus parts to do it...
__________________
www.toyotacrawlers.com '85 4runner: 4.7's, FoxFab sliders, custom bumpers, 1" body lift, F-150 springs rear, lockright, welded third, IFS rear axle, 1.5" wheel spacers, high-steer, rears up front, Longs, 38" SX's on steelies, 12Voltguy dual battery, soft top, BMW seats. NO LONGER lacking an engine. :D :D |
#20 (permalink) |
Super Moderator-Sponsoring Member
Staff
If you have to ask about how much it costs you can't afford it.
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale |
#21 (permalink) |
I want to see a swap on a late model rig done with less than 30 man hours that is not hack.
On the old junk, heck we could do leaves in long weekend. Using good parts cost good money. Doing a built high pinin custom axle is a lot better and more expensive than doing a stocker with just a rebuild. |
#22 (permalink) |
People, this subject has been argued to death...it's like
for every person that says it will be more than 5K , there's someone who say he can do it for 10 bucks using old parts from deserted air plane on a deserted island. what we need to do is just ask the guy what he can/can't do. We can just give him choices and he can make up his own mind as to what the total will be. It's all depend on what parts he's willing to spend and what he's willing to leave out. I can get a 2x2 square, weld a D44 ends to it and run D44 tie rod/s teering. Weld some hangers and put rear toy springs on it and call it a day. That's should be less than 200 bucks. Oh you want it in 4WD?...with drive shafts and gear/diff? and bigger tires too and have the rear to come up the same height? .....Oooooh , that's gonna be extra.
__________________
http://www.angelfire.com/ca6/954runner GOD's Country Best Seen In A 4 Runner. SAS front: lf,ARB,Ml4",Marlin arms, rear: cable elock,APlinks,OEmu860,35MT/R 5spd, 4:1. ..."But officer, that was not an illegal turn, it was just an undocumented turn." Last edited by anthony1; 06-28-2005 at 04:46 PM. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Solid Axle Swap Has Begun!!!!! | 93ToyKid | The Fab Shop | 85 | 05-19-2006 04:47 PM |
| Tacoma Solid Axle Swap | WATRD | The Fab Shop | 459 | 12-24-2003 06:21 AM |
| Cheaper Solid Axle Swap? | jsrusse11 | The Fab Shop | 30 | 12-17-2003 08:29 PM |
| solid axle swap questions | SteveO | Offroad Tech | 56 | 09-29-2003 11:04 PM |
| Yota 87 Solid Axle Swap | lcopelan22 | Offroad Tech | 5 | 09-10-2003 09:42 AM |
