rear chevy springs?
rear chevy springs?
i've heard of this swap being done, but i'm not sure how it's done. what chevy truck do these springs come from? do i have to relocate my rear shackle hangers or do i move the front spring hangers farther forward? or both? do i use the entire spring pack or just the main spring? i've got 4 inch springs on the front now and homemade spring packs in the rear. what would i use to get me back to level or slightly higher in the rear? i'm working on a 91 shortbed with a sas up front if that helps anyone who can help me out here.
Did you even TRY to search? Been covered a million times - try searching on 63" Chevy ... you should find a link to Pirate4x4 that explains EVERYTHING.
We did it on Molly's rig, and it wasn't as cheap or as flexy as people had led me to believe, but that was converting over a coil sprung suspension to leaves. It needed a 1" or so block to level it out, and it's a pretty low SAS.
pre-shaded (thanks)! a four link has been on my mind but not my bank account. just looking for more flex and a much softer ride. i'll check that out on pirate.
Welcome to YT...but this probably should have been posted in newbie tech...
TC is right..
but I am feeling nice this morning so here are some link that will answer your questions...
63" Chevy Spring Swap FAQ
Pirate 4x4 Toyota Frequently asked Questions
read these a few times...
add your truck info to your sig line too.
TC is right..
yep, new to this "yt", but not to wheeling. i'm a driver not a fabricator. just trying to get some info. thanks for helping me out with my questions. not sure what you mean by my truck info on my sig line? like i said i'm new on here.
Both of those are great and make me want to do it now
EDIT, Go to user CP, Click edit signature, Put what year and spec of your truck, it helps alot...
Sorta like my signature, it shows up in every post...Look down
Good job on the warm welcome guys...hahaha! what they mean by putting your truck on your sig line is...
91 Std. Cab Pickup, SAS, blah blah blah!!!!
And the 63's are a good swap..cost me about 120 bucks for parts! did the labor myself! After you do it there are some different things your can do to them to make them perform to their full potential...like taking the spring clams off and replaceing them w/ the taller bolt syle. putting new telfon pads on and cleaning the rub surface. im going to put TG's creeper joints on soon and that should help too!!! ill do a thread on them later!
Flying91
45
04-11-2024 04:39 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
terminator
07-27-2015 07:13 PM
