Rear bumper brackets on aftermarket swingout - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > The Fab Shop
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-12-2009, 10:07 PM   #1 (permalink)
BigBluePile's Avatar
Send a message via MSN to BigBluePile
Angry Rear bumper brackets on aftermarket swingout
Ok, here's the deal: there's a pretty good chance ya'll have seen my rear swingout bumper around:
This bumper, functional yes, has been a pain in my tailgate since the day I tried to install it. Please DO NOT ask me who makes this bumper 'cause I'm not gonna tell you!!!! I'm not gonna advertise for these clowns any further.
ANYWAYS, the mounts for this bumper were completely NOT thought thru and I tried to fix this issue when I first put the bumper on but to no avail. Now, it's really a problem. These brackets mount on the outside of the framerail and use the factory bumper holes. Because of this, the rear shackles directly contact the bracket and limit spring movement. Not to mention the obnoxious CLANG I get everytime I hit a pothole or flex out on the trails.
Here's the passenger mount from the outside:
Here's the passenger mount from directly behind it looking forward:
Here's the drivers side mount as a whole:
Now, I have two ideas to fix this problem. Number ONE was to have fab'd a one (1) inch spacer for between the bracket and the frame rail and bumper and bracket like these(disregard the little swirl thingy by the sharpie marker...stupid photobucket...):
Here I just used washers to simulate:
From the bottom with washers:
Now, I'm thinking this should work, but I am worried about there not being enough support along the bottom of the frame rail since the bracket is shifted so far over. I could have that lower piece extended an inch to compensate though. Also, will this cause MORE stress to the frame rail since the "lever arm" is longer(ie-it's not up flat on the side of the frame rail but farther out)?? I did oversize the spacers as much as I thought nessasary.
Number TWO. Years ago while engrossing myself in Yota knowlege on 4crawlers(thanks again Roger!!! ) site, I found where he made a kit form for a rear swingout bumper(http://www.4crawler.com/4x4/ForSale/RearBumper.shtml). Now, I already had the bumper, just needed the mounts, which he sells on their own. I'm revisiting this option. These mounts are like the factory in the way they mount INSIDE the frame rails and are in NO WAY interfering with the shackels.
Basically, I need some help deciding which way I should go. Get the spacers made(yes I could do them myself but since the only "me" time I get is after 8pm using a grinder is a little frowned upon...) or dump more money into 4crawler stock? LOL!!
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
THE ULTIMATE TOYOTA RESOURCE
'86 4Runner SR5 22R-E
4" Procomp/Superlift/Rancho 9000x/BudBuilt skids. Downey Header/Magnaflow exhaust, Supra AFM. 315/75R-16 Baja Claws, 4.88's, TrueTrac rear.
Rear disk kit/trans e-brake. Addicted Offroad winch bumper/MM 9000
Current pics
'06 4Runner Sport
270/65R17 BFG All Terrain KO's
Quote:
Originally Posted by Junkers88 View Post
Admit it, you like reading my posts. It reminds you of the days before your runner was the monster that it is now.
Last edited by BigBluePile; 09-17-2009 at 08:44 PM. Reason: Moved pics around in photobucket
BigBluePile is offline
Old 08-12-2009, 10:11 PM   #2 (permalink)
scuba's Avatar
KENNESAW MOUNTAIN BUMPER FTMFGDLB
hah
__________________
Screw you guys I'm goin to TTORA
Mods, please be mature and leave my sig alone, thanks.
No, I will not be your friend.
scuba is offline
Old 08-12-2009, 10:14 PM   #3 (permalink)
lawl
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
Current pics
'06 4Runner Sport
Old 08-12-2009, 11:42 PM   #4 (permalink)
algranger's Avatar
Do it right. Buy the 4crawler mounts. Believe me i push the line of ghetto fabrication on my rig and i speak with experience when i say you dont want to have a hack-job spacer weakening everything
__________________
I said lie, for me
lying under a process tree
algranger is offline
Old 08-13-2009, 10:48 AM   #5 (permalink)
bump!
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
Current pics
'06 4Runner Sport
Old 08-13-2009, 03:35 PM   #6 (permalink)
Plumbrbob's Avatar
the spacer deal seems like a quick fix maybe can be done easy with some steel tube, gussets, and a longer grade 8 bolt cheap, quick, and easy.
If you got the cash get the beefy looking mount FTW
let me ask you something?
do you plan on ever slapping on a set of longer rear spring packs? if you go for the typical after market type(TG,MC,AP) then you need to move the rear shackle mount back.
Now will the cheap fix or the costly fix be clear of that mod?
just looking ahead
__________________
79 YotA ThinG
Mods: http://www.yotatech.com/blogs/plumbr...list-mods.html
Plumbrbob is offline
Old 08-13-2009, 03:56 PM   #7 (permalink)
ScottyC's Avatar
Logan, look in my thread and build some brackets that slide into the frame rail and weld in place. Its the only way to make it strong enough. The brackets are easy to make out of 2x3 .188 or .250 wall tubing.
__________________
Scotty
http://www.addictedoffroad.com/
970-420-4198
Toyota Winch bumpers on SALE!
ScottyC is offline
Old 08-13-2009, 05:24 PM   #8 (permalink)
just looking ahead
Rob, true I can do this cheap an easy but I want to make sure it wont cause unnessasary stress to the frame and I think it would "work." As far as upgrading to chevy's I think the bracket would be too close and bind the springs up under flex.
Now with the premade mount from 4crawler it sits inside the framerail and wont be an issue with the current shackel/springs. However, if I slide the shackle mount back it will be in the way unless I put a body lift on and have the bumper bracket just come straight out. Like this:
Also, this mount is easily adjustable to accomodate body lifts if I put one one, by simply moving the holes and cutting down the bracket.
Quote:
Indeed, that's why I was leaning towards 4crawlers design because it went into the framerails like you're saying(WHICH is why I got into an argument with those idiots the "built" this thing in the first place-yup the guy called me a liar on the phone and told me Toyota never mounted, or had, step bumpers that bolted in thru the framerails...).
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
Current pics
'06 4Runner Sport
Old 08-13-2009, 05:47 PM   #9 (permalink)
paynemw's Avatar
wait its a KMA bumper... F MY LIFE... i just paid for the downpayment on mine for the 3rd Gen 4runner... DAMN IT!
__________________
Matty P
2000 4Runner SR5 4x4 5 spd standard, Magnaflow Catback Exhaust, URD Sensor Simulator, ISR, Deckplate Mod, Black Rock 929 16x7's, custom sliders, KMA Multicarrier, URD stage II clutch kit
Will be ordered: ShrockWorks front bumper, OME 3" lift
My Build
paynemw is offline
Old 08-13-2009, 05:57 PM   #10 (permalink)
Quote:
Bummer dude, hope you get it this year:
http://www.yotatech.com/f2/put-my-dp...-night-163526/
Booooo KMA, BOOOOOOOO!
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
Current pics
'06 4Runner Sport
Old 08-20-2009, 05:21 PM   #11 (permalink)
Update, went with 4crawlers(thanks again to Roger for his help!!) mounts and will post when I get this all together.
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
Current pics
'06 4Runner Sport
Old 09-10-2009, 06:00 PM   #12 (permalink)
Alright!! Well, I finally got my brackets from 4crawler(no thanks to the post office...lazy). So, today I took the bumper off again and ground off the old mounting brackets on the bumper itself and installed the frame brackets. Now I just have to tack it all together and slave the bumper on for clearances and I'll be able to get this done.
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
Current pics
'06 4Runner Sport
Last edited by BigBluePile; 09-12-2009 at 03:23 PM. Reason: I moved pics in my photobucket account
Old 09-10-2009, 06:35 PM   #13 (permalink)
ocdropzone's Avatar
hmmm..i am gonna borrow your idea of slipping that c-channel into the frame rail to beef up my rear bumper mounts
__________________
~Robb
'81 Trekker The B4Runner Build
TREKKER Forum
Mini FAQ/Misc Ideas Thread
**TRY THESE SEARCH LINKS**
GOOGLE FOR TOYOTA WEBSITES
LINK TO ONLINE FACTORY SERVICE MANUALS
Drive a real 1st Gen
Wheel Responsibly, Don't Screw It Up for Others
ocdropzone is offline
Old 09-10-2009, 06:43 PM   #14 (permalink)
It wasn't my idea! LOL!! Thank 4crawler or Scotty at AOR, that's how they do they're rear mounts...as well as Toyota!
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
Current pics
'06 4Runner Sport
Old 09-10-2009, 06:46 PM   #15 (permalink)
ocdropzone's Avatar
Quote:
either way, it is a good one I'll just match it up to my Marlin mounts (it is mounted outside of the frame rail) and sandwich the frame between that and the c-channel..
nice thing is that I think I have some c-channel under my work bench that will work. just need a new drill bit..
__________________
~Robb
TREKKER Forum
Old 09-10-2009, 06:55 PM   #16 (permalink)
Nice! Just make sure to kinda knock the cornerns off because it's a freakin tight fit to get them into the frame rail.
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
Current pics
'06 4Runner Sport
Old 09-12-2009, 03:20 PM   #17 (permalink)
Update, 12SEP09
Alrighty. So, I scored a 110v fluxcore wire feed welder from the local pawn shop and today tacked all the bracketry together. Tomorrow, hopefully, I'll be able to tack the bumper on the the brackets and it'll be ready for the pro's to finish welding it. I might add some gussets in places to provide more strength. I've only got ONE problem!! Because my truck DOESN'T have a body lift I can't get the frame brackets out now! lol! So, I'm either gonna have to take the body mounts apart(which I could do because I have replacement body mounts in hand, just no new hardware) and lift the body up or cut notches in the body frame to get them out.
Hmmmmmmmmmmmmmmmmmmmm...
As you can see, these new brackets will not interfer with the shackels anymore. I may even clear 63" chevys if I go that route.
Theres my little Schumacher EZ flux welder. Works great!
Yes, the tailgate clears when I open it.
Theres the problem, so what do you guys think?? Notch it or pop the mounts?
Nice lookin dual exhaust, eh?? For square 2.5" reciever tubing, it's definately beefier than what use to hold the bumper together.
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
Current pics
'06 4Runner Sport
Old 09-12-2009, 06:05 PM   #18 (permalink)
Any thoughts?
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
Current pics
'06 4Runner Sport
Old 09-12-2009, 07:13 PM   #19 (permalink)
ScottyC's Avatar
You need to gusset both sides of that plate otherwise it will just bend. This is why I use 2x3 for everything and still gusset it.
__________________
Scotty
970-420-4198
ScottyC is offline
Old 09-12-2009, 07:48 PM   #20 (permalink)
Will do, I was planning on going ahead and putting gussets on the bumper side. For the frame side I'll just have to run a stiffner.
I still have to figure out how to get the darn frame brackets out!!!
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
Current pics
'06 4Runner Sport
Old 09-12-2009, 09:40 PM   #21 (permalink)
algranger's Avatar
Lookin good.
I dont see what your problem is there though
__________________
I said lie, for me
Old 09-13-2009, 12:04 AM   #22 (permalink)
RMA
Quote:
Originally Posted by algranger View Post
Lookin good.
He cant take the brackets out.
Just take the whole truck to who ever is going to weld for you and have them do it like that... with the brackets in the frame .
Dont cut the body , if you really have to take the body mounts off and lift it.
__________________
'89 2wd X-tracab,W55,22re,My DD
'94 SR5 4Runner 4x4,A340H, 3VZE,Alpine deck,Wifes DD
'88 SR5 4runner ,A341E,1UZ-FE,kenwoodVZ907,
XRC8, Homemade Roof rack.33x10.50,15 KM2
1" home made body lift, BJ spacers ,CB, rear disc brakes ,lockright rear.sky ebrake,truetrac front.
My swap thread
http://www.yotatech.com/f161/1uz-fe-...0-3vze-185324/
RMA is offline
Old 09-13-2009, 08:17 AM   #23 (permalink)
Hmmmmm, well I suppose I could drive the truck there. Don't know if I want to truck my tack welds in traffic! lol!! I might just have to lift the body, cutting a notch looks ok?
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
Current pics
'06 4Runner Sport
Old 09-13-2009, 09:50 AM   #24 (permalink)
4Crawler's Avatar
Any thoughts?
Should be able to turn the bracket to the inside to swing them out of the frame:
Your frame might be a little tighter than normal, if so, see if you can grind out the tack welds and pull out the piece in the frame and grind it down just a little where it is hanging up. I recall once having to grind a little notch back along the channel just at the point where it would hang up on the frame rail, just a small notch to allow the channel to rotate out of the frame rail.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 09-13-2009, 12:22 PM   #25 (permalink)
Hmmmm, yeah, trust me I tried to bring the bracket toward the center. It's a no-go. I'll probably have to grind the tacks off and notch the bracket in the one spot. The drivers bracket fits in smooth, but the other side not so much. The frame rail has gotta be tweeked a little.
We'll see, I tacked it all together pretty darn well.
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
Current pics
'06 4Runner Sport
Tags
4crawlers, 97, aftermarket, bracket, brackets, bumper, bumpers, mounting, number, phone, rear, road, tacoma, toyota, winch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
