YotaTech Forums
Go Back   YotaTech Forums > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > The Fab Shop
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 04-15-2004, 10:32 AM   #1 (permalink)
Personal Sales Rating: (0)
Mikronized's Avatar
Double Cardan Angle? | Rear Leafs?
ok, so I have 2 questions.
1. I have a driveline angle of 15* right now and am getting a grinding noise at high speed. I plan on getting the driveshaft reversed and a double cardan joint put on next thursday, but what angle does the rear diff need to be once the CV is on? which takes me to 2. how do I tilt the rear diff when I have all the control arm crap mounted to the axle? I could get adjustable upper links but those only adjust to 1" longer then stock? ..... so how many of you have gone rear leafs? i've seen that sschaefer3 and steveO have both done it but how easy is it on a 2nd gen? also how much would it cost to get it done by a shop? cause I don't have anyway of doing most of the work myself..
thanks for your help guys!
__________________
'94 4runner : soon-ish to be V8'd, SAS'd, lock'd and bumper'd
'04 Xcab Tacoma 4x4 TRD : Stock
Mikronized is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 04-15-2004, 10:56 AM   #2 (permalink)
kyle_22r's Avatar
i'm no driveshaft scientist, but i believe you want the rear diff to point at the t-case output flange for a cv shaft.
i think that the easiest way to go to rear leaves is to ditch the stock axle housing and find a '86-95 rear off a truck and then just weld hangers to the frame. then again, it might not because it sounds like you'd want to redo the perches anyway(for more pinion angle)
__________________
1998 tacoma, 3RZ-FE, 5 speed, 30x9.5R15 M/Ts
past toys:
1984 4x2
1979 4x4
1991 4x4
kyle_22r is offline
Old 04-15-2004, 11:22 AM   #3 (permalink)
Threadstarter [OP]
Mikronized's Avatar
Quote:
that's what I thought too, but the local driveline guy said not because then the needles will wear a dead spot because of a lack rotation in the ujoint.
I just don't know
__________________
Old 04-15-2004, 11:30 AM   #4 (permalink)
SteveO's Avatar
Send a message via Yahoo to SteveO
Quote:
I just don't know
If you get adjustable control arms and did adjust the axle to point straight towards the t-case, your coils would not sit striaght on top of the axles. Which, without clips to hold the coils in, could be pretty dangerous.
The next thing, get some 4" All-Pro leafs, and do the conversion. Or talk to Schaefer about his setup with Chevy leafs. I would think he speced out some smaller leafs before going with the 63" mongo leafs. However, if you don't get the axle just right when you weld on the upper perches, you'll experience the driveline problem still. Then the pinion bears wear out, and the t-case wears out, a whole host of fun issues.
SteveO is offline
Old 04-15-2004, 08:17 PM   #5 (permalink)
upndair's Avatar
The leaf spring conversion on the second gen is far superior to the coil spring suspension. The job is not terribly difficult but it is quite time consuming. You'll have a hard time finding a shop to do this kind of work due to liability issues. You may want to talk to the guys at Allpro about doing the work for you.
__________________
Gibby
1994 4Runnner
6" lift: Leaf spring conversion rear, SAS front. 1180 Ramp score.
DANA 60s with ARB lockers
39x13.50 IROKs
SBC 350, NP203 - NP205
Allpro bumpers and rock sliders.
www.faithwheelers.com
upndair is offline
Old 04-15-2004, 09:01 PM   #6 (permalink)
Shane's Avatar
Send a message via AIM to Shane
Find a new driveline guy, quick! In fact, just talk to Jesse.
On the angle topic, yes if using a CV at the transmission end you want the pinion to be pointing at (actually 1-2° BELOW for a rear axle) the transfercase output. This is to account for the axle rotating up under load.
On the perches vs axle swap, you'll have to redo them either way to get the proper angles so just keep what you have and make it work.
__________________
"It's one great big dysfunctional family that now has to split up and spread dysfunctionality around the greater world," Bill Stainton on the breakup of the cast of "Almost Live!"
Shane is offline
Old 04-15-2004, 09:04 PM   #7 (permalink)
Shane's Avatar
Quote:
Last I heard AllPro no longer does any work on customer's vehicles.
__________________
Shane is offline
Old 04-16-2004, 06:49 AM   #8 (permalink)
SteveO's Avatar
That is exactly what I did on my setup. When I setup my rear suspension, I measured it all out, and set the pinion down 1* to account for pinion climb. I also had Tom Woods retube my drive shaft with 1/8" wall and balance it for me. Thus far, I have had it on the highway to Las Cruces, about 4 hours, and no issues. I'm very pleased with the setup.
Click on the photo to see more....
Click the image to open in full size.
SteveO is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
60, angle, balance, calculator, cardan, conversion, cruces, dana, double, driveline, end, las, pinion, rear, trans, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Removing the double cardan U-Joints Crazychopstick Offroad Tech 10 09-22-2011 02:33 PM
Double Cardan centering ball hutch24 86-95 Trucks & 4Runners 6 12-20-2006 07:17 PM
double cardan shaft tubing size? tech Offroad Tech 1 10-15-2006 06:11 AM
Grease for Drive shaft/slide yoke/double cardan jtmaxx7 95.5-2004 Tacomas & 96-2002 4Runners 16 05-18-2006 12:05 AM
Double Cardan installed! Mikronized Offroad Tech 2 04-24-2004 08:16 AM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
