Cb Install
Old Dec 26, 2006 | 08:05 PM
ROOFGOOF's Avatar
Cb Install
Yo,
What tool are you guys using to cut out the plastic where the ashtray is ? I bought a Cobra 19 CB and want to stick it in there...I've seen a few people on here do it but cant find any write ups , etc.
Its for a 3rd generation 4runner.
Thanks a billion.
Tim
Old Dec 27, 2006 | 04:33 AM
91 4Runner's Avatar
I used a small hacksaw (just handle and blade - no back bone), but others will say a dremil...
Old Dec 27, 2006 | 09:35 AM
seanz0rz's Avatar
Guest
dremel with a tungsten carbide bit, works great and doesnt melt the plastic too bad.
else you can use a razor knife to carefully score through the abs plastic.
Old Dec 27, 2006 | 12:22 PM
ROOFGOOF's Avatar
Cool...after that are you guys just basically just stuffing the CB in there with some foam tabs to keep it tight and no vibration or are you actually mounting the bracket inside the hole ?
Cheers!
Old Dec 27, 2006 | 01:30 PM
KyleT's Avatar
i used aluminum strap cut to make a bracket for my sat radio reciever there. I am hoping that my cb will fit under it too. post a pic when done though.
EDIT. i unbolted the ash tray, didnt have to cut anyhting. it does have that little hump there. not sure how different it is from a 99 to a 96. my moms 2000 is alot different though.
Old Dec 27, 2006 | 02:01 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
i just used the dremel with the regular cutting blade and then foam double sided tape strips to secure it in there. it was solid as a rock
Old Dec 29, 2006 | 02:47 AM
91 4Runner's Avatar
I just drilled a hole on each side of the opening (inside the astray mount hole so you cannot see the bolts) and put the right CB bolt through and tightened it then put the cb in place and installed the other bolt... Snug as a bug....
nvdesertrunner
May 11, 2020 08:18 PM
wwjr
Sep 7, 2015 09:27 AM
punks_is_4x4
Aug 21, 2015 01:35 PM
Esibnitsud
Jul 30, 2015 08:19 PM
