Building a skid
Building a skid
2nd gen 4Runner. Plan on building something like this. WHat material thickness should I go for on the square tube? I don't want to go overboard on the thickness as it isn't going to see hard offroad use, just trails with some rocky bits. Nothing I can't get through with a gentle right, rear locker and stock gears.
The plate is going to be 3/16"
At least .120", but you don't need any bigger than .188".
That said - the pictures are either a Tacoma or 3rd gen 4Runner - the frame is different - no bolt holes for the factory crossmember, which is right in that area.
Something like a budbuilt crossmember would do 90% of what this contraption does, but a lot simpler
The Budbuild/ TG x-member would be great, but I can't afford to drop $250 Canuck bucks into this, I think I can do this version for about $75 all in for materials and beer for the welder.
.120 wall would be plenty and cheap. I bought like an 6' stick of 2x4x.120" to build my cross member that also sports my 3links for the front end. I just cut and welded the factory transfer case skid to the cross member for now...
Toys4parts
09-26-2015 01:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
Aaronmarston
09-22-2015 09:39 PM
2nd, 4runner, build, building, case, crossmember, daveindenver, dimensions, dual, gen, single, skid, toyota, yotatech
