Aluminum Tow Hitch
Aluminum Tow Hitch
So here is what i was thinking:
Trying to save weight is important for both reliability and a daily driver.....so
I currently making ""a-NUTHER"" gas tank but this time i am giving it a shot with 1/8 alum sheet
Anyways--i was going to build an aluminum bumper with tow hitch included. but i started looking under there and decided to leave the old bumper--trim a bit and add in raised tow hitch (C-Channel slid into the frame and bolted in OE spots). This hitch will also tie into an intergrated rear skid frame covered in UHMW--which also acts as the gas tank skid/protection
Thinking:
OEM Hitch is 3/16 steel with (~58K-70K PSI tensile & 50K Shear) Weight--about 50 lbs
But if you wanted to build a slightly tougher yet LIGHTER one--What would you use?
6061-T6 Alum?
Chromo Tube?
Bolted 7075-T6?
Other?
TC--are you there
Thinking:
6061-T6 Alum?
Chromo Tube?
Bolted 7075-T6?
Other?
TC--are you there
FS[MidWest]: 1.5" ball joint spacers
4x4YOTA
08-23-2016 09:08 AM
Cycles
09-29-2015 06:37 AM
Odin
09-26-2015 06:56 PM
mirabile4runner
09-03-2015 07:15 AM
