3.0 oil pan swap
Old 09-15-2004, 05:46 PM
TheTank's Avatar
3.0 oil pan swap
I'm getting ready to start my SAS in about a month (already got my "new" axle!!), but I've read a couple places that with the '85 front axle and stock 3.0 oil pan, the differential will put a major dent in the oil pan because it is shaped for the IFS differential. I read one guy took the oil pan off and cut a section out and welded a new piece to clear the differential, but I don't really want to get that involved. Is there any way that the T100 oil pan with the rear pickup tube will just bolt straight up to my 3.0 like you can do on the 3.4L??
Old 09-15-2004, 06:20 PM
914runner's Avatar
The 3.0L and 3.4L share the same block. When I did my engine swap, I hade to bolt my 3.0L oil pan in place of the stock 3.4L oil pan, so it should bolt right on!
Old 09-25-2004, 06:51 AM
Adam F's Avatar
I have no problems with mine
Old 10-09-2007, 10:09 PM
cjhuntsman's Avatar
a little off topic but is there a way to remove the oil pan without dropping the trans(auto)?
Old 10-09-2007, 10:18 PM
4RunnerKid's Avatar
it's more the tie rod that hits the oil pan... i believe the 2wd 3.0L oil pan is another option for gaining clearance under there.
Old 10-10-2007, 11:17 AM
UKMyers's Avatar
Use a 3.0 2WD pan. It's a direct bolt on. The 3.4 baffle plate requires some drilling and tapping. Look in the Offroad Tech section for my write up.
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Jdgarrison
10-01-2015 05:22 PM
09-04-2015 09:27 AM
toyoda8488
07-05-2015 10:18 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 3.0 oil pan swap
