| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
2nd Gen 4Runner Lower Link Skids
__________________
95 4runner | 2" Spacer lift | 265/75/16 MT'S | Pro Comp D-Window Stealies | Lower Link Skids | Custom Front Skid | Rebuilt 3VZ | Spectra Intake | 5% Tint All Around | Clear Corner-Blinkers-Tail Lights | Infintity Kappas | MTX Thunder Series 10's |
#2 (permalink) |
Keep in mind this is coming from someone who basically ripped one of the link mounts off the frame...
Just like the FJ Cruiser ones, I think this design is BAD BAD BAD. It does nothing but transmit the force into the mount, and actually acts as a damage multiplier. I have personally repaired 2 FJC frame end lower link mounts with these kinds of skids. If you want to do it right, remake the link mount out of 1/4" plate going up welding to the side of the frame instead of the relatively small amount of weld at the corner.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#3 (permalink) |
what are you saying to do? weld the whole assembly to the lower link mount? (was planning on doing that eventually just test different ideas out.) or are you saying to strengthen the skid up? its as strong as it will get. everything is welded thoroughly on all seems. lmk all input is appreciated.
__________________
#4 (permalink) |
he is saying to plate the entire lower link bracket with 1/4" plate all the way to the top of the frame rail.
i havent had any problems with mine, they are the front hangers for my leaf spring swap on my 90 4runner, and get alot of abuse. best pic i have of it.
__________________
i drive by brail. Rock Solid Motorsports http://www.rocksolidmotorsports.net/ http://www.lunatic4x4.org/forums/forumdisplay.php?f=45 |
#5 (permalink) |
oh okay i see. just strengthen the lower link up by welding plates onto it.
__________________
#6 (permalink) |
those fail usually at the weld to the frame so you have to bridge that joing and weld to the frame. while your at it strengthen the upper link mounts on the axle, they also like to rip off the housing.
__________________
poop 1988 stock 4runner, v6, 5spd, soft top. 1990 fj62 stock and mint! 1992 4runner, 3.4, auto, SAS'ed, Marlin USA springs (4"/5"), 37" PBR's, 30 spline Longfields, Hydro assist, dual inchworms (5:1, twin stick, 23 spline, chromo output, 10* clock) 5.29's, lockrite's, custom exo, High angle drivelines drive shafts, 108" wheelbase, Warn hs9500i, Mcintosh/Dynaudio a/v system. The build up...http://www.yotatech.com/showthread.php?t=74915 |
| Tags |
| 4runner, lower |
