14 Bolt FF into a 1988 pickup
redoing spring perches, brake line routing, and modding your driveshaft(either by getting a flange to replace the yoke on the 14b, or having your driveline remade with a yoke for the 14 bolt)
that said, a D60 or 9" is a better swap for a toyota if you need a bigger ring gear
would be much slicker to use a flange on the yoke -- high angle driveline would probably be able to set you up with one. they're known for their fondness of toyota u-joints and have all kinds of flange conversions for american axles
Originally Posted by crash
Those diffs may be strong, but they are plain too big unless you wanna run at least a 44" tires to get any clearance at all...
Originally Posted by TinyTruck
yeah I know that the ground clearence will blow goats but I have plans for 40in tsls, that and people are either shearin ring and pinions or shattering spider gears (I dont wanna do either)
Originally Posted by runnerboy97
what are you gonna run for a front axle?
you do realize how much wider the rear is gonna be compared to the front, right.
of course I realise that, I may be 15 but I am certainly not that dumb A d60 or d44 will come when I get the $
I am going to start my new front here soon..... upgrade time
Originally Posted by Mikeyg79
Got a buddy with 40's, ran a stock 8" rear (think with cromos) and a D60 front.
Throttle happy guy with way low crawler gears.
You should re-evaluate your build
toy axles are pretty good units, unless you're crash. then they're a POS
keep in mind that a toy rear has 30 spline 1.3" shafts, get a V6 carrier and odds are unless you're crash, it'll be fine with up to 38s. front end shafts are now near bulletproof with bobby long's 30 spline birfields, i wouldn't hesitate to run 38s with them. of course, i've got a 4 banger, not a 4.3 with an SM465 and dual cases
14 bolts are best used for planting crops...
"QUOTE FROM A POST BY BOBBY LONG"
"We did some testing on some stock stuff all the way up the Dana 60 here's some numbers they broke at;"
Stock Birfield= 3,700 ft lbs
Birf Eliminator kit= 4,020 ft lbs
Stock inner shaft= 4,360 ft lbs
Longfield stock treated birf= 4,800 ft lbs
Superior 27 spline 4340 chromo inner axle= 5,200 ft lbs
Longfield 27 spline 4340 chromo inner axle= 6,820 ft lbs
Longfield 30 spline 4340 chromo inner axle= 8,200 ft lbs
Longfield 4340 birfield stub failure= 8,200 ft lbs
Stock Dana 60 35 spline= 8,300 ft lbs
**UPDATED FIGURES**
Stock Toyota Birfield, 27 spline ................ 3,700 ft-lbs
Toyota Birf Eliminator kit ...................... 4,020 ft-lbs
Stock Toyota inner axle, 27 spline .............. 4,360 ft-lbs
Pigs 4340 Toyota inner axle, 27 spline .......... 4,700 ft-lbs
Longfield stock treated Toyota birf, 27 spline .. 4,800 ft-lbs
Superior 4340 Toyota inner axle, 27 spline ...... 5,200 ft-lbs
Longfield 4340 Toyota inner axle, 27 spline ..... 6,820 ft-lbs
Yukon 4340 Dana 44 inner axle, 30 spline ........ 7,900 ft-lbs
Longfield 4340 Toyota inner axle, 30 spline ..... 8,200 ft-lbs
Longfield 4340 birfield stub failure ............ 8,200 ft-lbs
Stock Dana 60 inner axle, 35 spline (used) ...... 8,300 ft-lbs
Stock Dana 60 inner axle, 35 spline (new) ....... 8,320 ft-lbs
**UPDATED FIGURES**
