| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#26 (permalink) | ||||||
Staff
__________________
94 4runenr: all the good stuff....... 89 4runner: 3.0, Auto, 5.29 lockright f/r. 31x10.5 wildcountry ATs. 81 2wd pickup: 22R | 5-sp | long bed |Civic SI seats | LockRight | Hella 500s pacific-crawlers.com For all your Trail-gear and HID lighting Solutions Needs check out yotaworks.com Online store coming soon :) |
#27 (permalink) | |
Quote:
I missed this before, what do you want for the coils?
__________________
-Joe Z Chicago 4x4 My Webshots 1985 Toyota 4Runner, 3" Trail Gear rear/ All-Pro front springs, 42x14 IROK's, Allied Rockathons, spool rear/detroit front, 30 spline longs, Dual cases w/4.7, Marlin High steer, lots of other stuff.. 1997 Dodge 2500 4x4, 12valve CTD, not stock. |
#28 (permalink) |
Very nice looking rig. It'll look awesome with the SAS and 36's.
__________________
Drew 99 4Runner SR5, auto, 3.4 V6, factory rear locker, 265/75 Yokohama Geolander AT+II Stock for now, but hopefully not for long. |
#29 (permalink) |
Looks like you are doing exactly what I plan on doing in the future. I will be waiting to see how it turns out. Good luck with the rest of the build!
__________________
~93 4Runner~ 33" MT/R's, fj80's in rear, and ball joint spacers in the front |
#30 (permalink) |
Ok I got back in the garage today, and between changing the brakes on a KIA I got some work done, not much but its going pretty smooth. The next thing im waiting for is the plasma cutter, then I can begin cutting everything.
I was wondering how you guys move the steering box forward, mine has no room to be moved, I can maybe go 1/4" before I hit the body mount. So what am I missing here?
__________________
poop 1988 stock 4runner, v6, 5spd, soft top. 1990 fj62 stock and mint! 1992 4runner, 3.4, auto, SAS'ed, Marlin USA springs (4"/5"), 37" PBR's, 30 spline Longfields, Hydro assist, dual inchworms (5:1, twin stick, 23 spline, chromo output, 10* clock) 5.29's, lockrite's, custom exo, High angle drivelines drive shafts, 108" wheelbase, Warn hs9500i, Mcintosh/Dynaudio a/v system. The build up...http://www.yotatech.com/showthread.php?t=74915 |
#31 (permalink) |
you usually have to cut a hole in the radiator core support. the more bodylift you have the less you have to cut.
#32 (permalink) |
I just got done researching this. I think im just going to try to move it as far forward as possible (with no cutting) and rotate it as far forward as possible. I should be able to get it all to fit then.
__________________
#33 (permalink) |
Super Moderator-Sponsoring Member
Staff
I'm not sure what the differences for different gens, but I didn't have to move/cut anything out of the way, but I have an 85.
Here's a pic:
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale |
#34 (permalink) |
he wants to move the box forward from that wabbit. imagine that front bolt all the way up to the frame body mount. yes, that is what he wants to do.
#35 (permalink) |
Im going to call Sky to see if any of there pitmans will alow me to leave the box where it is. Or aleast not make me move to far.
__________________
#36 (permalink) | |
Staff
Quote:
__________________
#37 (permalink) |
then you can move the axle THAT far forward as well.
greater approach angle and keeps the tire out of the firewall, also helps with d-line angle, and helps f/r weight distribution a tad. |
#38 (permalink) | |
Staff
Quote:
__________________
#39 (permalink) |
Im getting off to a slow start. Im having trouble getting ahold of the guy who im buying the plasma cutter off of then I have to wire 220 out to the garage. Before I buy the wire I need to know what the amperage pull is. Its capable ot cutting 5/16" plate (i think) I also am having trouble getting my 3rd back from the guy who is setting up my gears, so I cant begin to rebuild the front axles.
hopefully once I get the cutter this job will speed up. But its going very smoothly so i cant complain Ill take slow and smooth.
__________________
#40 (permalink) | |
Quote:
__________________
Greg |
#41 (permalink) |
Trail gears pitman arm is the same drop as factory, so its not going to solve his problem.
__________________
#42 (permalink) | |
Quote:
__________________
Greg |
#43 (permalink) |
yea it looks like im getting my plasma cutter and maybe my 3rd on saturday so now this "turtle speed" build will speed up. Or ill take weeks figuring out how to set up and use the plasma cutter, oh well both will be fun. because bottom line Ive got a plasma cutter that was only used once and almost new (for $200!!!!!!!!!!!!!!!!!!!!!!!) HEHEHEHEHEHEHEHEHEHEHEHEHEHE
__________________
#44 (permalink) |
Score! Great find. good luck with the SAS. Cant wait for the pics to star showing up.
__________________
Will WabFab Off-Road, LLC Toyota 4x4 Parts and Custom Fabrication updated website with lots of new products 87 runner with every bolt on available |
#45 (permalink) |
Ahhh finally some progress. I've got a toy (plasma cutter) that I never thought Id have but for $200 and a spare kit of consumables, I couldnt pass it up...
This thing is great it cuts like crazy. which is good bc it took me all day, 6 cutoff wheels, and 2 grinding wheels just to get the all the bracketry off of the rear axle. This takes a long time with no help (although tonight my fiance 62girl (jenn) helped a lot) I put my swampers on the axle so I could have a sort of portable jackstand setup, it worked great until I had to move the 400lb beast by myself. well not that I got much done tonight but I made some head way and actually got some cool pics of grinding in the garage My woman lending a hand I just really like this pic with my jenns 62, my 88 runner and the 92 in the garage Although this isnt a rare occurance, I often have a fj80, an fj62, an fj60, my 88runner, the neighbors 94 runner, my 92 runner, my other buddies 92 runner, all in and out regularly. Well tomarrow I hope to remove the front end. BTW I talked to marlin and they mentioned that the steering box doenst need to be moved, they said it will work and that is how they set up all their trucks.
__________________
#46 (permalink) |
Hey, all of you who have done leaf conversions on your runners, what did you do with the upper arm bracket that is bolted to the gas tank, i dont want to take my plasma to it. It doesnt seem to be in the way and it is part of the bracket for the gas tank, just curious. Also did you guys have to move the gas tank, (I doubt it bc the leafed toys have the same tank) Things are moving along. Its awesome but it doesnt make for good right ups bc its the same old sas, oh well ill post pics tomarrow.
__________________
#47 (permalink) |
__________________
#48 (permalink) |
Thats cool your doing the SAS conversion did you buy the kit or fab it your self? and what did the solid front axle cost? I want to do this mod really bad but can't find an axle, also what gearing are you using?
#49 (permalink) | |
Quote:
$150-axle $140-gears (5.29) $75-gear setup kit $160-Profields $225-knuckle and bearing kits $230-locker $100-wheel spacers $80-rotors $50-pads $70-(nonfactory 4.88)3rd member $20-diff armor total=about $1300 I chose 5,29's bc with a 3.0 auto, geared 4.88 with 35" AT's on alloys I needed more rpms. So with 36" swampers, on steelies, I will definatly need the 5.29s. Axles are really easy to find, check the classifieds on pirate4x4 and here.
__________________
| Tags |
| 36x1450x15, gumbo, tires |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 92 SAS 4Runner | 4RocRunner92 | The Classifieds GraveYard | 73 | 10-11-2007 09:01 AM |
| 92 SAS or hold out for Newer toy | fatdudesurfin | General Vehicle Related Topics (Non Year Related) | 2 | 10-25-2006 10:11 AM |
| 92-95 runner bumper work on 91 runner? | 914runner | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 05-25-2004 11:17 PM |
| millionth tire question on this site | SoCal4runner | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 08-28-2003 01:10 PM |
