1986 Toyota Pick-Up 4X4 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > YotaTech Community > Check Out My Truck (Noobs, do not ask for tech help here) > Trucks, 2nd gen-'84 to '88
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-02-2007, 03:48 PM   #1 (permalink)
CanTheWhales's Avatar
<<<New Pictures Coming Soon>>>
Current:
stock 22R, G52, & RF1A
4.10:1 gears
100,xxx miles original
Net weight as it sits with a full tank = 3,440 lbs.
Flex-a-lite Black Magic 165 electra-fan
Pro Comp ES3000 gas-celled shocks
Pro Comp ES1000 steering stabilizer
removed factory anti-sway bar for additional flex (HAHAHA)
33x12.50x15 Pro Comp Severe All-Terrains
15x8 (3.75 BS) Pro Comp Rock Crawler Series 51 wheels
Bride black cloth racing bucket seats (slide/recline)
5.56MM ammo box custom center console
PowerTrax Lock-Right Locker by Richmond Gear (rear)
LC Engineering Billet Carb Adaptor w/ K&N Pre-Charger/Dry-Charger Filter
LC Engineering 304 Stainless-Steel Ceramic-Coated Street Pro Header
LC Engineering 304 Stainless-Steel Ceramic-Coated Street Pro Exhaust
(30" Resonator, Magnaflow Turbo Muffler, and 3" Stainless Polished-tip)
Fabtech bed-mount angled spare tire carrier
FuzzBuster Z80 40-channel 2-way CB radio w/ 102" steel whip antenna
(and another Uniden sittting right next to it.....long story)
Explorer Pro Comp Series 55 H3 Halogen off-road spot-lights
Marlin Crawler 300-series Rear Rock-Tube Bumper (w/ pintle hitch & 3.75T Shackles)
Marlin Crawler Front Winch DOM Tube Bumper (w/ relocated turn signals)
Bed-mounted 60" Hi-Lift Xtreme Jack
Sweet cooler I found on the side of the road (now in bed, in custom welded rack)
Vinyl floor removed and poly-bed coating sprayed down
Future Plans:
  • All-Pro Off-Road In-cab Cage Kit
  • Crow 5-point weld-in racing harness
  • Roof rack for more lights (can't have enough)
  • SmittyBilt XRC8 8000 lb winch & a Pull-Pal
  • 12-Volt Guy dual battery kit with Optima Blue-tops
  • Yukon Gear 4.88:1 F&R
  • Sky Manufacturing driveline parking-brake kit
  • Budbuilt T-case skid plate and driveline lift
  • tube cross-member and 12" Pro Comp MX6 Remote-Reservoir Shocks (rear)
If I wasn't a poor college student:
  • Yukon full spool and Bobby Long Chromo shafts in rear
  • Detroit LSD and T100 CV's up front
  • Total Chaos Gen. 2 full Caddy kit
  • 8" FOA coilovers (front)
  • Total Chaos rear SUA suspension w/ Deaver F62 leaf springs and 9" Shackles
  • twin 16" Dirt Logic adjustable shocks out back
  • SAW 2.5 airbumps on all corners
  • 37x12.50x15 Pro Comp X-terrain's on Hutchinson Rock Monsters (3-piece int. beadlock)
  • Marlin Crawler Dual Ultimate Transfer Cases
    (2.28 Lo in front, 4.7 Lo in back case, 10.716 Double-Lo combined)
  • FJ80 disc's in front with V6 calipers
  • Sky Manufacturing rear disc-brake conversion
  • fiberglass F&R fender/quarter panels and tubbed bed
  • full internal 12-point race cage & 5-point harnesses
  • paint...?
CanTheWhales is offline
Tags
1986, 19861988, 4x4, bumper, case, forums, front, manual, pickup, racing, seats, toyota, transfer, truck, winch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
1986 4x4 Toyota Truggy MorphiasX The Classifieds GraveYard 1 02-11-2007 02:12 AM
timing ? 22rtec 1986 4x4 pick up tampabayota 86-95 Trucks & 4Runners 1 02-10-2007 10:16 AM
Anyone with 1986-1988 Toyota pick-up brochure? That i could get off you? BCtoyota 95.5-2004 Tacomas & 96-2002 4Runners 0 03-08-2005 05:05 PM
Toyota pick-up 1986 turbo???? GG_GLI 95.5-2004 Tacomas & 96-2002 4Runners 5 06-18-2003 03:59 PM
1986 toyota 4x4...what engines will fit? mx3man83 95.5-2004 Tacomas & 96-2002 4Runners 7 01-06-2003 10:17 PM
2009 InternetBrands, Inc.
