Arizona Arizona Chapter
K&N Air filters
Old Apr 25, 2008 | 09:25 PM
wormhole's Avatar
K&N Air filters
How well do the K&N air filters hold up to the dusty conditions here in Arizona? I had one on my old corolla and camry and had no problems but I was in Missouri and Idaho/Utah where it wasn't as dusty.
Old Apr 25, 2008 | 09:33 PM
fillsrunner4's Avatar
Trap lots of dust but I think a dryflow filter is a better option
Old Apr 25, 2008 | 09:38 PM
Elton's Avatar
go with a trueflow its a foam filter
Old Apr 26, 2008 | 01:02 AM
Elvota's Avatar
Does Amsoil make one for your application? I like the one I ended up with... I guess you could mod your 3.4 intake like I did. Pretty easy to do, and cheap.
The Amsoil uses no oil. If you go with a filter that does use oil, be sure not to use to much or that can be sucked through and cause havoc with some of your sensors.
Old Apr 28, 2008 | 05:28 AM
sschaefer3's Avatar
I have always had a K&N on my 4Runner, it works fine, I use that pre-charger as well in the Volant intake setup.
I have had no problems.
Old Apr 28, 2008 | 09:54 AM
Belize Off Road Team's Avatar
as long as you clean your K&N filter more often than most people seem to, i do mine every 6 months unless i went through alot of dust then i do it way more often. but i notice a better MPG and maybe slight power but i dought it. after my experiance with K&N you will not catch me dead with anything else unless TRD makes a cleanable filter for my 3.0
JUST CLEAN YOUR K&N ALOT AND YOU WON'T HAVE TO WORRY ABOUT ANYTHING.
Old Apr 28, 2008 | 09:21 PM
wormhole's Avatar
Thanks for the replies guys.
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
accuracy
Aug 4, 2015 08:05 PM
Toyvana
Jul 29, 2015 10:47 PM
ryerye13
Jul 14, 2015 08:27 AM
