What limits 2nd gen IFS max compression ? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-28-2005, 07:50 AM   #1 (permalink)
nrgetic99's Avatar
As my stock compression forward bumpstop was fouling my OME shock, I replaced the compression bumpstop with llow profile ES jobbies.
In messing with lifting the truck on the outboard ball joint on the lower arm , it seems I can get no where near the bumpstops.
I have not tried removing the sway bar yet but it seemed to me that the shock was compressed to its max (OME N98) and limiting upward travel.
I will try repeating without the shock but is it likley the sway bar lmits upward travel so much I can not even hit the bumpstops ?
Thanks
David
__________________
98 Limited: Taco/Tundra TRD/OME lift, diff drop, LC rims, 32" REVOS, TJM T-17, Magnaflow
93 SR5 V6 4WD *** TOTALLED **OME lift, Aisin hubs, 31x10.5 Dueller ATon 15x8 AR23's, clears, Silverstars, K&N, Dynomax, Yakima ...
03 V8 Sport. Jaos Center Protector, Landmaster Dual beams, Silverstars, RD leather interior , TRD rims/X-Terrains - gone :-(
99 SR5 "Highlander", SC'd, SAW/Downey,32's,Addco,deck plate, TRD cat back, 1.5Kw stereo ...gone , not forgotten
96 SR5 Dune... 1.5kw stereo
nrgetic99 is offline
Old 10-28-2005, 07:56 AM   #2 (permalink)
snap-on's Avatar
Send a message via AIM to snap-on
sway bar will limit travel (up or down)
its (relitivly) easy to pull both the sway bar and shock and see how your travel changes.
if you have cranked your torsion bars then its possible to be unable to get enough weight on that corner of the truck to compress it completly.
__________________
94 EX cab, 5speed, V6, locked, ARB bar, NWOR headers
92 4runner, auto, V6, OME suspension, Downey headers
snap-on is offline
Old 10-28-2005, 08:06 AM   #3 (permalink)
Flygtenstein's Avatar
Torsion bars.
If you are cranked, piss off. You likely were barely using your stockers, let alone low profile ones.
Stock bars with BJ spacers is the best IFS front. You actually use the small travel window you have.
__________________
Ease on down the road.
Flygtenstein is offline
Old 10-28-2005, 08:10 AM   #4 (permalink)
nrgetic99's Avatar
Quote:
Originally Posted by Flygtenstein
Torsion bars.
Thanks.....
As I stated, the low profile stops were a cheap solution to replacing the stock one which fould the shock body at full droop. They were not really put in to allow more upward travel.
Not cranked yet. Was thinking of just cranking for now to level truck until I get the BJ spacers and diff drop (I have Aisin's)
Not sure on the ' piss off ' comment , does that mean something different in American ??
David
__________________
Old 10-28-2005, 09:52 AM   #5 (permalink)
FilthyRich's Avatar
Quote:
David
That actaully has me laughing....
__________________
Eric
88 4runner
Quote:
Originally Posted by AxleIke
"Just wheel what you got until it doesn't cut it anymore".
FilthyRich is offline
Old 10-28-2005, 10:22 AM   #6 (permalink)
nrgetic99's Avatar
Quote:
Me too...I could not find a sarcasm smilie
David
__________________
Old 10-28-2005, 10:39 AM   #7 (permalink)
RobG's Avatar
David
I could never get my front to compress using a jack, on the trail though I had no problem hitting the bumpstops. I think it was because the rear was super flexy compared to the front.
Key to max stock IFS travel is to keep the torsion bars soft and disconnect your swaybar. Best solution is to lock the front your only going to get so much flex out of the stock IFS front.
And as far as I know there is no diff drop (other than a bracket lift kit) for a 2nd gen, that's 3rg gen stuff.
__________________
'93 4runner 4WD/V6/5spd
RobG is offline
Old 10-28-2005, 10:57 AM   #8 (permalink)
I mean forget about it.
When I had Sway Away bars, an ARB bumper and low profile bumpstops I could only hit them when I jumped the truck.
With the same bars, BJ spacers, no exposed thread on the adjustors and bumpstops, it would crawl to the stops.
__________________
Old 10-28-2005, 11:01 AM   #9 (permalink)
nrgetic99's Avatar
Thanks....
I have drained the mod fund for this month plus my energy from crawling under the truck every night is running low.
I was going to go with custom height BJ spacers less than the 1 5/8" BUT now it seems that lift hight with the spaces then trim back DOWN to perfect ride height (for me) with the torsion bars will be the best of all worlds... smoother ride and longer travel.
David
__________________
Old 10-28-2005, 11:03 AM   #10 (permalink)
nrgetic99's Avatar
I think Roger does a diff drop kit for 2nd gens now.....
here
David
__________________
Old 10-28-2005, 11:32 AM   #11 (permalink)
RobG's Avatar
here
David
I stand corrected, looks like he rotates the diff around the front mount to provide an inch of drop.
Very Clever.
__________________
RobG is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
pushing an IFS toyota to its limits mochester 86-95 Trucks & 4Runners 17 02-27-2007 08:50 PM
gear for a 2nd gen with ifs rivercat The Classifieds GraveYard 4 04-16-2006 03:40 PM
max tire size for IFS? ToyoRunner94 Offroad Tech 15 07-27-2005 08:31 AM
Max Tire Size for locked IFS? VT_Toy Offroad Tech 9 10-21-2004 02:03 PM
Locking 2nd Gen IFS - Max Tire Size? VT_Toy 95.5-2004 Tacomas & 96-2002 4Runners 1 09-28-2004 01:11 PM
2009 InternetBrands, Inc.
