Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
What can a stock 4Runner do "Offroading" wise?
I am new to 4Runners and Offroading in general, but I was wondering what a completely stock '89 4Runner could do. I want to test out the 4wd and have some fun but I don't really know what the limits are. The car would be my daily driver so nothing too crazy that could possibly break my car but what are some suggestions for Offroading. Should I avoid water and mud? Should I use paths? Anything is appreciated and I look forward to enjoying the 4wd capabilities!
| Sponsored Links |
#2 (permalink) |
As far as mud and water, nothing above the front bumper, your air intake is right behind the headlight so if you go any deeper than that then you could hydro-lock. Search that if you dont know what that is. Id stick to more basic paths untill you get a feel for it. Your biggest problem is going to be ground clearance. Id say flex but youd sooner hit the front cross member on somthing before you starting getting on possible flopping angles. A decent set of tires would go a long way if your running like all seasons or whatever too. Do you have any pics of your 4runner?
__________________
1988 4runner- 22R-E - Crazy Gear Parting with the "Slush Box" If You Cant Feed IT - Dont Breed IT T urning O ver after Y ears O f T rail A buse |
#3 (permalink) |
Being new to 4 wheeling I would definately start out simple. Get in touch with a local 4wheel drive club possibly a nearby ttora (www.tacomaterritory.com), they are usually very helpfull for all types of Toyotas and trails. Your stock toyota is a very capable wheeler depending on driver skill and the limits you are willing to push. Paths (better known as trails) should always be used and not strayed from, (unless its your land or you have permission from someone that owns the land). As always, be safe, have fun and tread lightly.
__________________
1986 4runner 31" mt's aftermarket shackles Custom front bumper/winch Light bar/auxilary lighting Rear Detroit future mods: 33's maybe 35's, 5.29's, Rear bumper with tire/jerry can,highlift mounts, sliders. Conquer with the IFS until I can't conquer anymore and then do an SAS. |
#4 (permalink) |
#5 (permalink) |
Yes, keep it on the trail, tread lightly is the key. You don't want to harm the environment and ruin 4x4'ing for the rest of the crowd like many choose to do.
You should be good to go on the stock runner, I keep away from the mud and water and stick to the trails and the rocks. One suggestion if your going to start offroading and start modding and you get on the trails is to get sliders.
__________________
97 4runner, 2.7 5speed 4wd, 4.556, 255/85/16 Maxxis Bighorns rear diff breather, 4 hella 500's driving, sliders, wilderness rack custom bumper arb locked rear toytec adjustables, ome 891's, bilstein 5125 manual hubs broken front and rear swaybars My Profile |
#6 (permalink) |
#7 (permalink) |
First, NEVER wheel alone.
Second, you need a recovery strap and solid tow points front (the factory hook is good) and rear (clas III trailer hitch works nice) Better to start off too easy (like a dirt road) than find yourself on something too hard with a broken truck and not enough recovery skills/practice to get out safely. x2 on hooking up with your local TTORA chapter
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#8 (permalink) |
Yea, find someone that knows what the heck they are doing/where they are going....never wheel alone and never wheel on private property or public property without permission. Carry more recovery gear than you think you will need......
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
#9 (permalink) |
What type of exterior stuff would suit me well?
I have always wondered, what do those extra lights do that people have on their front bumpers? Would bigger tires help me in any way? |
#10 (permalink) | |
Quote:
If you want to protect your nice clean body....maybe some bumpers, sliders and skids.... The lights on the front bumpers are usually just for show to look cool at the mall...there are much more important things you can spend your cash on. Auxiliary lighting should be one of the LAST things you do. If you are wanting to upgrade your lights I would recommend upgrading your stock headlights. Roundeyes sells nice conversion lights that work well with an upgraded headlight harness that 4Crawler sells. Yes, bigger tires help ground clearance but you might need to regear your diffs and/or suspension lift depending on how big you go
__________________
#11 (permalink) |
Staff
Where are the diff breathers on the 1st gens?
If they are like the other Runners you will want to relocate them higher up to help in water crossings. Fink ![]() |
#12 (permalink) | ||
See Avatar.....nuff said
__________________
Quote:
Quote:
93 Runner, 3vze, auto, 4.88 gears, 31" tires, mostly stock, 255k and counting DD: 94 runner, 3vze, geared 4.56, m/t, 31/10.5/15, only 200k on the clock Project: 91 p/u, 3vze, m/t, 2" body lift, 4.10 gears, 33's, 219k on the clock. It's becoming an addiction. |
#13 (permalink) |
Hey 4x4,get your truck running alright?
#14 (permalink) |
Start with some taller tires,better shocks,but make sure what is on the truck is in good shape, ball joints,steering, etc.Get a high lift jack,northern tool has them on route 60.Also a recovery strap.I put a class III hitch mount front and back on mine,and I can place my winch if its needed.{four times at hatteras already this year pulling Gm and ford P.Us out of the sand}Make sure the truck is ready to go,mechancal and safety wise.
#15 (permalink) | ||
X2, what fink said.
Search diff breathers, don't want water getting in there! And as far as aux. Lighting, i like mine, use them a lot, basically another set of high beams. Don't do much offroading at night so they are not necessary but for the area i live it was worth the $50. Other than that, when you get it, probably do a tune up and just start out easy and test your limits slowly. Like has been stated, never wheel alone, have tow points, have recovery gear, spare parts/tires, etc.... Good luck, im sure you will like it if you get the 4runner. Any more info on the truck? Engine, mileage, etc...
__________________
Quote:
Quote:
My build thread http://www.yotatech.com/f152/904_run...thread-158746/ Last edited by 904_runner : 07-14-2008 at 11:09 AM. |
#16 (permalink) |
Search on YouTube for Moab, fins n' things 4runner.
i saw that and thought it would be a good example of a stock 4runner.
__________________
-Phyl 1991 Hilux Surf SSR-G Petrol 3.0L V6 193,000kms l 3.4L V6 264,000kms to be rebuilt then installed! l Rancho RS5000 l 31"x10.50"xR15 Pro Comp Xterrain l K&N Drop in filter l PP 1" Lift Coil Springs l TRD shift knob l Lv. 3 First Aid Kit l White Gauges & Temp Controls l LED conversion l 80/100W Hella H4 l Hella Black Magic l 1st Gen Roll Bar Mod l FT/RR Diff. Breathers l Smittybilt XRC8 Winch l TOYOTA TOUR 2008 トヨタ|NEVER QUIT
#17 (permalink) |
My '88 was pretty like that...until I got a rear locker. Then I locked the front and it will go places it has no business going! In all seriousness, if I was starting with a stock 4Runner, I would get tires (31's fit stock) and a rear locker and go from there.
#18 (permalink) |
Get a budy who can pull you out,
and FIND OUT what it can do. You will only learn from doin it, just dont do anything too stupid like try and jump off a 5 foot drop into a mud hole bc someone said it would be badass. Have fun.
__________________
86 4runner SAS swap Dana 44 front 7" sus front 6" sus back 3" body DRIVE LIKE YOU GOT A PAIR! |
#19 (permalink) |
Stay away from water thats over the bumper. I've pushed my way through many holes where the water was mid way up the grill and even had a quick wave up onto the hood and no problems, but all it took was once. Game over, new motor time.
Now a usefull item that could help you out in these situations is an intake snorkel. They can get pretty pricy but you can build one out of PVC pipe for about $20 and if you do it right they fit nice and close and don't look too homebuilt! Keep in mind there are many other things in your engine bay that are still not protected but if you find yourself in trouble atleast you don't need to worry about hydro-locking your engine. Other than that you will be amazed at what these 4runners can do in stock form. If you don't want to get into any modifications than I would advise you to pick yourself up a set of good 31" tires. They will make a world of difference and 31s will fit just fine. Happy trails!
__________________
'90 Hilux Surf - sold '86 4Runner - sold Hoping to start another project soon, LT race build. |
