Valvoline maxlife?
Valvoline maxlife?
Has anyone got any feedback on this oil? I need to do an oil change this weekend and have heard from friends that this has worked well for them. I am kind of skeptical using a synthetic oil in my truck because I have no idea what the previous owner used. (conventional/synthetic weight etc.) The truck is a '94 22RE w/110k miles on it.
-TIA
-TIA
Is there a legitimate reason why you shouldnt use syn after regular? Its highly possible im just ignorant about this, but I havent heard that before and def have changed back and forth in other vehicles.
no idea, all i know is the syn leaks through places the regular might not. and also I've heard that most wear on an engine occurs during the first 2500 miles....or somethin like that.
Wasnt aware they had a non-synthetic version. Its funny, when I went on the Valvoline website they have a section where they tell you what oil is right for your vehicle and they told me I should be running maxlife synthetic.
Bob is right, use the regular Maxlife. My old Mazda started smoking like a SOB (worn rings) and I changed the oil with the Maxlife and 90% of cleared up.
I've been using Maxlife (non-synthetic) for a while now. No problems at all. 4Runner has 191,xxx miles on it, and runs great. Does have a few oil leaks, but that has been there since before I switch oils.
Originally Posted by Rivalred
I am not too much of a fan of Valvoline, but Maxlife might be different. When I use to do my oil changes I loved my Castrol GTX.
Well its decided then. Conventional maxlife for me
Now I just have to figure out what weight to run. I have a noticeable valvetrain chatter and have heard that heavier oils reduce the noise significantly.
What weights are you guys running?
arizona shouldnt get too cold, so 20-50 should be fine
however, heavier oil will just mask noise, valvetrain chatter can eventually lead to a engine failure and if its that bad, you need t ohave it fixed properly
oils
Try this link ,it might help on your choices a little more.bob200587 is correct on "family traditon"I used havoline and fram,but now I use GTX and mobil 1 filter
http://www.nordicgroup.us/oil.htm#The
Valvoline and Castrol is equivalent to Ford vs. Chevy........mostly comes from family tradition, and or personal preference. I'm sure that we could do a study on which one does better....but im not up for doing an experiment.
But all the reason and experience comes through the senses which is all relative.
chuckross1957
09-07-2015 09:34 AM
