SAS or Total Chaos
SAS or Total Chaos
Ive been into wheeling for about 2 years now. I have a 88 4Runner, mostly stock...rebuilt engine, rebuilt tranny, new clutch, starter, etc...basically a solid drivetrain. I usually go to hollister hills to 4wheel but i have been recently intrested in dunes. My question is what would i be better off with a Marlin SAS or Total Chaos long travel lift. I would be doing all the work myself with the help of a few friends. Two of my other buddies mainly rock crawl and trail run but they all enjoy the dunes alot.
The consensus around here is if you are asking if you need a SAS, you probably don't.
However, if I were to spend the money, I would most likely just put a straight axle underneath because its stronger.
if you plan on doing high speed dune runs, long travel ifs. if your gonna just drive thru the sand, and want a good set up for rocks, sas.
the suspension with a sas just isn't designed to react the proper way with desert running. so it comes down to what time of sand runs do you want to do?
Personally, I'd probably do the TC kit if I had a 3rd or 4th gen. 2nd or 1st, I'd do a SAS... that's just me. I guess it depends on what you're going for. Ultimately, you can build a solid axle for more articulation than any kind of independent. But because of the increased unsprung weight it won't react as quickly as independent.
lol
Yeah, I think everyone want's a SAS
Well, at least I do. I would love to put it together... Thats almost more fun than anything else (sometimes at least).
lol
If you are primarily interested in running dunes, long travel IFS is the only way to go. The front solid axle will weigh you down too much, and won't handle going airborn as well as the LT kit will.
If you'r gonna get really crazy in the rocks.....you want an SAS. But if you're smart with IFS, you can get pretty damn far. Flygenstein has done some pretty tough stuff with his relatively stock IFS.
I do a 50 50 mix of fast riding and slower trails and long travel IFS leaves nothing to be desired. But the realist inside me knows that if I were primarily a rockcrawler I would want an SAS.
Now SAS isn't terrible for fast stuff. Look at the Jeep XJ's in teh Jeepspeed races they haul butt. My friend with and XJ keeps up real nice in the fast stuff. BUT, he bounces around a hell of alot more than I do.
Another time we were all jumping our trucks in superstition. All of us IFS guys were catching air and landing allright. But the 2 SAS guys both ran itno trouble. Fartrucks landing was super harsh and I think he said he killed a shock or two. Then our other buddy with a built XJ smashed his downpipe with his axle. That big axle has to go somewhere.
Check the video:
http://sethmetal.com/truckimages/sup...umpinfools.mov
I covered the sounds with music, but if you compared the soudns of the landings, you could tell that the first two trucks landed much softer. Not that jumping is what we all plan to do with our trucks, but I think it is a testament to taking harder hits.
Check the video:
The hardest problem im running into is...4 of my buddies run solid axles, and one wants to SAS. We mainly do trips down to Hollister Hills (trail & crawl), but all love dunes and Pismo. From all of your experiance what would i be better off with, considering most of my buddies are solid axle rigs. Do i go against the flow and start a craze with baja or do i stick with them and trail/crawl?
Well, do you want to get made fun of in the rocks, or make fun of them in the sand??
How often do you think you will get out to the dunes? Have you ever riden in a long travel truck? Have you ever ridin in a Solid axle truck in the dunes? I would suggest doing both before you decide.
How difficult are the trails that you're friends are doing? You can do alot with long travel setups.
I don't think any of us can/should make that decision for you. It's really best left to the vehichle owner.
I would stick with IFS for its ride and TC's durability. Look at it this way, if you ever do decide to go SAS after you get the Total Choas, you can switch and sell the TC. If you decide to go SAS then back to IFS your screwed. I'am a big fan of IFS. I pulled more SA trucks out than I have IFS due to the clearance of the front diff. Rocks on the other hand, your IFS has a harder time.
James
James
