| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Ring and Pinion...Is more better?
__________________
~ Those who hesitate are not only lost, but miles from the next exit! ~ 1990 4Runner SR5, 3.0L V6, 5-Spd. ~ 3" BL ~ OME 900 ~ 32x1150 Dueler AT's ~ Magnaflow Cat-Back ~ Optima ~ Manual Hub Conversion ~ FLX-165 ~ Hella 530s ~ ISR |
#2 (permalink) |
IMHO, it is not worth it to only make that small jump.
IMHO, this is off-road tech. I am not exactly sure how you got a 2 pinion diff in a 4wd V-6. |
#3 (permalink) |
Axel code G252. According to off-raods chart, is 2 pinion. What results from only having 2 as oppsed to 4?
__________________
#4 (permalink) |
I think 4:88's is just right for 33's with a manual. With that said 4:56's are certainly livable . If you must regear, I would find a bad rear (3rd) and rebuild it and find a wrecking yard factory 4:88 front . Then sell your 4:56s to recoupe you cost. BTW I don't think this is just offroad tech.
__________________
94 4runner 4cyl 5sp, SAS , rear leaf swap ,Fj 80 front axle ,E-lockers 72 Datsun 510 2dr , v6 conversion in progress |
#5 (permalink) |
I agree with Adrian, that small a change probably won't be worth the expense unless you can find complete thirds for sale for cheap.
In the early years of the V6 diff (up to about '91), 2-pinion V6 diffs weren't uncommon at all. AFAIK, '88 V6 diffs were all 2-pinion. Also, to clear up a little possible confusion, the "pinion" in "ring & pinion" is not the same "pinion" in "4-pinion". They are entirely different gears. In order to swap from 2-pinion to 4-pinion, you have to get a different carrier. Swapping ring & pinions does not (usually) require this.
__________________
Dave Currently own no Toyotas :( Last edited by toy283; 10-21-2004 at 03:14 PM. |
#6 (permalink) |
thanks for the clarification.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Ring and pinion help? | b82ta3 | General Vehicle Related Topics (Non Year Related) | 8 | 07-02-2007 08:17 PM |
| ring and pinion and other questions | outdoorfever | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 08-11-2004 07:44 PM |
| How much for a Ring and Pinion swap?? | williemon | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 08-02-2004 08:21 PM |
| ring and pinion | toy4fun | 95.5-2004 Tacomas & 96-2002 4Runners | 15 | 10-09-2003 01:34 PM |
