Potential New Adjustable Air Shocks...
Old 06-04-2006, 06:19 PM
  #81
ravencr's Avatar
That would probably work best. Thansk Adrian.
Chris
Old 06-04-2006, 06:21 PM
  #82
mt_goat's Avatar
I didn't drill mine out, I pressed them out and pressed in some the right size.
Old 06-05-2006, 09:59 PM
  #83
ohio's Avatar
Well, my solution was to chamfer them a bit with a utility knife to get them started, oil the hell out of the studs and bushings, and force the f-ers on. It worked.
They worked like a charm. I was completely on the overloads at rest, now I'm perfectly level at about 90psi and the ride is sooooo much smoother with the springs off the overloads.
Old 08-18-2007, 12:42 PM
  #84
Adam F's Avatar
Just wanted to say thanks to ravencr for the idea and part number on these shocks. I have a bit of sag in the rear, and the wife complains the truck bounces too much, so I gave these shocks a try. Just got them on and they seem to ride pretty good. At about 45psi the rig is leveled. 90psi puts the truck up in the air at least 3" lift. I will also use it for towing the boat.
I just wish I fully read the thread about drilling out the lower bushing. I had a hell of a time with it. Ended up heating up a big bolt with a torch and melting the bushing, and then using some grease to get it to slip on. Other than that it was simple. Used a sawzall to remove the rear shocks.
Old 08-18-2007, 01:34 PM
  #85
ravencr's Avatar
Glad you like them...it's been a while since this post originated, glad folks are still using the information.
Chris
Old 08-19-2007, 06:31 PM
  #86
Adam F's Avatar
Too bad there arent any $70 front air struts!
Old 08-19-2007, 06:37 PM
  #87
ravencr's Avatar
Yeah, no kidding.
Chris
Old 08-21-2007, 04:01 PM
  #88
86 yota's Avatar
Hey guys i was wondering if these would work on my 86 yota pickup. I tow a lawn trailer and often have a 1000 lb of feed or whatever in the back of my truck. I was wondering what the ride was like on the road unloaded and loaded. My truck sags when loaded and i was just looking for options to improve the suspension without taking away the driveability and off road capability. Thanks guys
Old 08-21-2007, 04:07 PM
  #89
ravencr's Avatar
Take the stock shocks extended length and fully compressed length, then look at the guide online and I'm pretty sure you'll be able to find a set that would work.
Chris
Old 10-26-2007, 09:08 AM
  #90
ravencr's Avatar
Just wanted to update folks on these shocks since I put them to work recently. I bought my old 1997 4runner back from the guy I sold it to in April '06. It's got almost 140K miles on it now, and I had to pick it up from Billings, MT. Well, my work vehicle(Kia Sorento) doesn't have a hitch, so I towed it back on a Uhaul Car Hauler from Billings, MT to Fort Collins, CO with the shocks pumped up to 95 psi. It worked great and never bottomed out in the rear. Surprisingly, I was towing roughly 6500 lbs at 60 mph and still got over 10 mpg, which I was happy with. The shocks definitely made it possible, because otherwise I would have been buried.
Chris
Old 07-18-2015, 11:40 AM
  #91
22rrr's Avatar
99 tacoma
was wondering if anyone has modified the monroe ma700 for a 99 tacoma?
Old 07-18-2015, 01:47 PM
  #92
ravencr's Avatar
Serious resurrection from the dead!
Chris
Old 07-18-2015, 04:26 PM
  #93
22rrr's Avatar
hey chris. have you tried monroe and gabiel shocks?
Old 07-25-2015, 10:30 AM
  #94
22rrr's Avatar
guess no one has tried the monroe ma700 on tacomas. thanks anyway.
Blamalam
03-12-2022 07:34 AM
bighaydn
08-04-2015 07:17 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
krimsonone
07-29-2015 11:53 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: Potential New Adjustable Air Shocks...
