YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Offroad Tech
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-06-2008, 04:35 PM   #1 (permalink)
Question Odd Torsion Bar Adjustment Problem
First a little background. I bought my 94 4runner about a year ago, didn't do a vehicle history report, later found evidence that the front passenger side was involved in a collision. I bought 31's for it and began noticing an intermittent rubbing problem on the right front passenger side. Turns out that side is about a 1/2 - 1" lower than the driver side. So last week I decided that I could fix the issue by cranking the torsion bar on the passenger side a bit to get the extra lift I needed to even out the vehicle and fix my rubbing issue. I ordered the torsion bar adjustment nut and bolt and have been spraying the nut and bolt with PB Blaster for a few days. Today I decided to get into it and found out that the nut on the passenger side is completely different than the nut on the driver side (and the one from Toyota) and that the passenger side has a lot more threads showing compared to the driver side (note the pictures). I cannot tell if the passenger side is cranked way low and that is the reason for the sag on that side or if the passenger side is way high as if someone already tried to do what I'm doing to fix it, and therefore there is a much different issue that needs to be fixed.
Here are 2 views of the passenger side:
And the driver side for comparison:
Thanks in advance for taking a look.
Mike
__________________
1994 4runner SR5 3.0L
WI_Mike is offline
Sponsored Links
To remove this ad, register today!
Old 09-06-2008, 05:11 PM   #2 (permalink)
rhale's Avatar
the passenger side is cranked much farther in or tighter which will raise that side. the more threads showing on top the more that side is cranked.
rhale is online now
Old 09-06-2008, 06:04 PM   #3 (permalink)
crackerjack's Avatar
Ya might as well break that thing off and get new parts. I cranked and pried on mine until the bolt and nut shoot up into the cab floor. Kapooow what an explosion be careful !!
__________________
33x12.5x15 pro-comp front/Swampers back , L.C Eng. cam,pistons,header, Crane multi spark ignition, Zoom Carbon clutch,etc. 8.5 Ramsey winch,4:88 gears open front, spool back. Vs2 backup camera, Lowrance GPS, Sirius Sat Radio, Tacoma bucket seats, tube doors, AllPro sliders and rear bumper Budbuilt crossmember....Thanks Yota Tech links to most this stuff
crackerjack is offline
Old 09-06-2008, 07:45 PM   #4 (permalink)
That's what I figured. The problem I have now is that even with it cranked up dramatically that side is still noticeably lower than the driver side, meaning that there is a larger issue that I need to compensate for. I think I will probably get a 1.5" BJ spacer for that side and loosen up on the torsion bar and hopefully make my ride better without the rubbing.
__________________
WI_Mike is offline
Old 09-06-2008, 07:55 PM   #5 (permalink)
Matt16's Avatar
Whoa, I wouldn't do one side only, that will seriously screw up your handling and ride. You'll get some seriously messed up steering.
__________________
1990 Toyota 4Runner 22RE 5spd
Rear Aussie Locker [click here for the review] *Nokian Vativa A/T tires* OME suspension* York OBA* pretty much stock.
Quote:
Originally Posted by DaveInDenver View Post
Yeah, I do think it's sort of funny. Can't you see a roomful of Toyota engineers looking at a relay rod, scratching their heads and saying 'Hmmm, this part wore out after 200,000 miles and 16 years, this is just unacceptable.'
Toyota FAQ link
More info on 4Runners
- awesome resources
Matt16 is online now
Old 09-06-2008, 08:00 PM   #6 (permalink)
Bigblock's Avatar
So someone took the upper control arm off and put it back together out of time.There should be marks that line up on the shaft and the front flang where it bolt to the control arm.Check the FSM.
Bigblock
Bigblock is offline
Old 09-06-2008, 08:06 PM   #7 (permalink)
maybe take it to an alignment shop and see if they can find out the reasoning.
X2 on not just putting bj spacers on one side!
__________________
Quote:
Originally Posted by Sin91
If i am awake, I am horny; ask Abe!
Quote:
Originally Posted by 4rnr View Post
I have NOOO $$ Im a poor college kid I recently started working so I decided to SAS.
If I dont sas Ill just waste money on chili cheese dogs and beer then Ill be poor, fat, and STILL on ifs.
My build thread
http://www.yotatech.com/f152/904_run...thread-158746/
904_runner is online now
Old 09-06-2008, 09:07 PM   #8 (permalink)
drew303's Avatar
Theres no guide key on the stock torsions, they dont fit in " one " way. In other words just because the one side has more bolt used than the other doesn't mean one is "cranked" up.
Besides, you don't actually crank anything when you adjust torsion bars, you change where the spring action (or the torsion) starts.
Take the weight off the front end, loosen the torsion bars completely and take them out and reinstall them back properly.
On a side note, that is the wrong configuration of nuts for the adjusting bolt. Should have a large (lil longer than an inch nut) with a second nut (of normal size) ontop, This locks the bolt in place from moving.
__________________
1987 Toyota P/U 4x4 pics/info
drew303 is online now
Old 09-06-2008, 09:14 PM   #9 (permalink)
Well, I think I'm going to take it in and have a professional look at it, this is slowly starting to get out of my league. Thanks again for all the help.
__________________
WI_Mike is offline
Old 09-06-2008, 09:31 PM   #10 (permalink)
drew303's Avatar
Maybe this picture will better help people understand how the Torsion bar works. As you turn that nut, and bring that arm down closer to the head of the bolt (ie, tightening the bolt) ... This just changes the the angle of the A-arms. Not the rate of the torsion bar. There is already a preload in the upper A-arm. I personally don't know how the innard of the upper A-arm is designed as I've never taken one apart but it has it's own spring rate. In other words it doesnt just pivot, it has tension.
As you turn the torsion bar up you reduce the amount of useable torsion, which is why you get a stiffer ride. If you just put the torsion bar in without preloading it (tigthening it under no load, say the truck is ont jack stands) then you would be utilizing all of the availbe spring rate the bar has. The A-arms would hit the upper and lower bump stops on full up and down travel. As you keep tightening (turning) the torsion bar in a postive way you start using up the available spring rate. The torsion bar is only going to twist so much under the fixed wieght of your truck. As you turn it, you start using up that available twist. So, to keep beating this dead horse, as you tighten or "crank" as you all say, your ride quality gets worse and flex less as you pre-set the torsion spring rate closer to it's max twist (the most twist it's going to do given the weight of your vehicle)
It's a slow night, I felt like explaining =p
*** correction, there is a spline that is bigger on the ends of the torsion bar but I remember either end fitting on at different angles. In other words, the torsion bar will fit into the upper A-arm more than one way and same for the torque arm on the opposite end.
__________________
Old 09-07-2008, 06:09 PM   #11 (permalink)
elripster's Avatar
It is very unlikely you'll find a "professional" who will know what to do unless it is an a Toyota centric off road shop. Typical alignment techs don't know a thing about suspension, just red and green numbers on a machine.
It's common for the adjuster hardware to rust and snap when adjusted. So, it's very possible someone just found something to work that is not production.
Replace both adjuster bolts with new. Now, adjust the bars to your desired height. Measure from the frame to the ground to make the truck is level side to side.
Go to www.sdori.com, there are alignment instructions that you should at least try to do before brining it in. Even if you don't feel you have it quite right, it will be very close and any alignment tech will then be able to do it. If you bring it to a shop with the alignment out by a lot, good luck.
Frank
__________________
1994 4runner, 3.0, auto, 5.71's, Truetrac (rear), 33's, BJ spacers, Coil spacers, air shocks, D-ring anchors, 4Crawler F/R swaybar discos, Marlin rear bumper.
www.sdori.com
elripster is offline
Old 09-07-2008, 10:24 PM   #12 (permalink)
The thing is I don't think there is any more room to get any additional height out of the passenger side. I don't need to get a whole lot out of it I just want to go back to stock height, but I would prefer if it was done properly.
Does anyone know of a good shop in the Salt Lake City area? There is a shop close to me that has helped me with a few other mechanical issues on the truck that I think I am going to call tomorrow and see if they have any experience in this area.
__________________
WI_Mike is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Torsion bar adjustment prob ????? swerks 86-95 Trucks & 4Runners 9 08-21-2008 10:05 AM
Torsion bar adjustment blueyoda Offroad Tech 4 04-21-2008 10:15 AM
Torsion Bar adjustment? Justinvd 86-95 Trucks & 4Runners 15 10-29-2007 04:08 PM
Torsion Bar adjustment with AAL dwiegand 86-95 Trucks & 4Runners 1 08-13-2007 10:04 PM
torsion bar adjustment...help! UGATruck 86-95 Trucks & 4Runners 22 06-25-2006 08:12 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
