maxing out my travel?
guys if i use rancho 3"springs and shocks along with an additional 2.5" spacers in front, would that max out my travel and kill my balljoints???
is this a SAFE setup?
Are the 3" Rancho springs for the front or the rear? If for the front, then no you cannot combine the two for a total of 5.5" lift. You will kill more then your bj's...
Originally Posted by slyang1012
yea its for my front...... anything i can do with the combo without hurting anything?
where would i be able to get a drop bracket lift?.. i have been seaching for tundra lifts.. but the only ones that are out is the TC for 4.5" lift tundra 4x4's and i have only a 4x2 wich only leaves me with 2.5 of lift no matter whatout there right now. is there anyway to fab up a suspension lift so that i can use the spacer/coil combo?? i want to go more than 2.5" without getting a Body lift.
THANKS
THANKS
3 inch spring and 3 inch body is all that is available. Lifting 2wd is tough to find parts. Maybe someone can make you a spindle to lift your front. I would look for a 3inch lift spindle and a 3inch spring.
Hope that helps.
Hope that helps.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
TheBFA
02-15-2020 06:55 AM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
1965chevy
09-20-2015 07:33 PM
sonorn67
09-19-2015 05:39 PM
