marlin 4.7 gearset on stock 4runner review
when i was rebuilding my engine, i went ahead and pulled the entire drivetrain and installed a marlin 4.7:1 gearset. the install was rather easy, providing you have the proper tools. (namely a press)
anyway, ive had a few opportunities to test it out and let me tell you, its a great investment for anyone with a 5spd.
no more stalling or smoking the clutch or cannon-balling over rocks, etc. 1st gear low with a little gas now and then lets me smoothly go over anything. no bouncing, jarring, etc. hill climbs that were once problematic i can now just crawl right up. rock ledges dont hold me back either.
also, i can fully lock up my front truetrac without having the pedal floored. that helps a lot as well.
btw: rear lunchbox locker, front truetrac, rolling on some 31's
even after bashing the hell out of my gas tank skid and my homemade t-case skid, and using them to slide over stuff, im just now being limited by lack of clearance.
the point: you should plan on lower t-case gears or dual cases much sooner than you probably are now.
turner
The 4.7 gearset has the bearings already pressed on. I just recieved mine tonight!
You will need a press to take the old gears off of the main shaft because it is being reused. I think thats how it works. havent started putting it back together yet. I'll know more tomorrow night.
Napoleon, did you have to clearance the shifter fork and the housing? I have heard some dont need it.
well since im not puttin the whole case back together, am i gonna need the main shaft? this gearset is goin in my donor/front case for a dual case setup
turner
turner
you will definitely need to clearance the shift forks, with the 4.7 set, there is no other way. die grinder or dremel will make quick work of it though.
i believe that you still need the press when doin dual cases. the adapter kit comes with a coupler shaft that replaces the mainshaft in the reduction unit, i believe it still needs to be pressed into the bearing.
some shops dont use a press (like inchworm), they just give it a quck heating with a torch and slide it in. personally, i dont like using the torch, but if you have a coffee maker, set it to warm, and put the bearing on the hot plate (you cant get it too hot, whereas with the torch, you could mess up the heat treatment), put the shaft in the freezer, and they will slide together easily.
yes thank you peter, while were on this subject, does anyone know where i can find directions (with pics) on how to install the 4.7's in the reduction unit and then assemble the crawler? marlins website has instructions for the 4.7 install, but the page with all the pics of MC09 build and the install dont really give any directions, a guy over on pirate did a writeup on exactly what i need but no pics, im not really familiar with all the different parts and their names so pics are gonna be huge
turner
turner
the majority of people put the 4.7's in the rear case versus the crawler box, so full on directions may be a bit difficult to find. you will probably have to mix & match the two sets to find the one you need
I think Marlin has made the Yota so much more "offroadable" by developing the case gearing options that he even deserves his own BBS icon
Update:
I started putting it back together last night and ran into a little problem;
I am missing the input gear!!! I guess I sould have inventoried the kit before I started. I am going to give Marlin a call today. I'm sure he will make things right.
yep, you will definitely need that. dont forget to transfer the snap rings over from your old gears! that has to be the #1 thing people forget when doing gear installs.
yeah, they are easy to transfer over, its those smaller c clip rings that are a pain Just getting one on is a 2 person job. ha-ha
cant wait to get it on the road with the rebuilt tranny and new t-case gears.
good, someone around here thats done it when i get ready to do my t-case gears, post pics up when you get my old skid installed
