manual hub gaskets
manual hub gaskets
I am looking at getting a set of used hubs. but is there a gasket inbetween the looking hub and spinder assembly?
if so what is the part number for it? Fel-pro, Toyota, ETC. or do I just use a small amount RTV sealant.
Also what size is the bolts on the hubs? I know their metric, any one ever measure them.
Not sure exactly which gasket you are asking for but:
The manual hub is attached to the wheel hub by six metric studs M8-1.25×~20mm (Toyota p/n 90116-08325) and six cone washers (Toyota p/n 42323-60010). You cannot use bolts in place of these studs. The manual hub cover is held to the hub by six small M6-1.00×~10mm bolts (no Toyota p/n available).
That "unknown " gasket is pt # 43531-60010 (at least for an 88 fj60, but it should be the same) There is also a "square" shaped O ring that seals the middle selector part from the outer stationary part. I'll post that # when/if I find the receipt in my car.
I wouldn't want to use silicone seal in the hubs. Might get inside and gum up the works.
I would go ahead and get the "square" o-ring also. I've bought 2 sets of hubs and both sets the o-ring was cracked/dry rotted. The dealer closest to my house has never had either gasket or the o-ring in stock. Wonder if any Nissan or Suzuki dealer carries them. Who sells Suzuki's now anyway?
the O-Rings where good.
Advance Auto and AutoZone didn't even have the part. they even crossed referenced the part numbers. well Advance Auto pulled up RTV sealant. so I used a small amount of RTV sealent.
kgcwb44
01-29-2023 10:02 AM
