IFS travel - who was measured?
#42
Flex info w/ the following...
Front: Tundra TRD 4WD Coils, 3/8" Thick Top Spacer, Bilstein HD Struts
Rear: Downey 2.5"/3.5" Coils, Conical Bumpstops, OME N86 Shocks
As you can see in the last two pics, the front didn't bottom out on the bumpstop and the upper A Arm did not touch the spring. No tire left the ground. I couldn't get it to max the front because the driver-side rear tire was about to rip off my flare. If I were to put a rock under the driver rear tire, then I could probally squeeze 8" of travel out of the front and maybe, just maybe a touch over. I gotta get that BL on for sure.
(from center of hub vertically to bottom of limited flare)
Front normal height: 21.75"
Front compressed height: 17.5"
Front extended height: 24.75"
Front overall travel: 7.25"
% of comp/extension: 70% of travel is compression
30% of travel is extension
Rear normal height: 22.00"
Rear compressed height: 14.00"
Rear extended height: 34.00"
Rear overall travel: 20.00"
% of comp/extension: 33% of travel is compression
67% of travel is extension
Pics of position during measurement:
#45
Last time I measured my front, I had 10.5" of front wheel travel. 15" compressed to 25.5" drooped. It actually compresses further than that on occasions.
#46
#47
I've been running '99 springs, OME shocks, 1" top out spacer for years. Lately this setup was "discovered" by Steve S. Recently I added Camburg arms which have higher angle ball joints.
Works pretty good IMHO.
#48
#49
I just installed a set of used Fox Fabtech Coilovers (thanks Brent) and a 1/4" top out spacer (thanks Jayson).
Here are some quick measurements with the drivers front stuffed and the passenger front drooped while the drivers rear is drooped and the passenger rear is stuffed:
Front
Normal Ride Height (with a 1" BL): 22.75"
Stuffed to the bump stops (Daystar lower than stock): 17.5" = 5.25" Stuff
Drooped (tire still on the ground): 26.5" = 3.75" Droop
Travel = 9.0"
Front
Travel = 9.0"
#50
Interesting that you have less compression measurement. It's odd. I installed the Camburgs because I had a lot of BJ interferance with the springs. The extra droop was just gravy that I didn't know I'd get. The other awesome benefit was the increased castor angle! It drives a lot better with less wobble/vibration. For me it was definately worth the money. They are expensive though.
#51
Less? Less than what? With 2.5" of lift, I think 5.25" of compression is better than average, certainly farther than my stock springs with spacers. It stuffs all the way to the bump stops. I even tried to put a credit card between the bump stops and the frame, no go!
#52
He's not comparing apples to apples here. He has OEM 99 springs. OME shocks, with a 3/8" top spacer. He has 1/2" of TOTAL lift. You can't compare droop and compression on an 1/2" lifted suspension to that of a 2.5" lifted suspension. Different starting points will yeild different droop/compression measurements.
#53
I don't think it's less, I think I get the max compression possible with these. The only way I could get more compression with the same lift would be to cut off the bumpstops and cut out the inner fenders. Those 33's really stuff in there. I don't think I could go to 35's like Schaefer has with these springs, they may be too soft for anthing larger than a 33" tire.
Now if I add more top out theoretically it should shift the shock body down adding more droop and keeping the same amount of stuff. It just wouldn't stuff so far into the fender well. I think I'll try that next, when I have time to pull the front end apart again.
Isn't this IFS stuff fun Maybe I'll just cut it all off and put a D44 in it's place...yeah right!
#54
Hmm, If we are both compressed to the bump stops, then I would think the measurement should be the same. Somehow I'm at 15" and you are at 17.5 but both at the bump stops. Wierd huh?? Maybe it was my airborne adventures with the 4R. At some point, too much top out and the shock will bottom out BTW.
#55
I do have a 1" BL so you can subtract an inch, but with that you still have 1.5" of compression over me? Strange?
#56
I have SR5 flares. Do you have the Limited flares?? That could account for the difference too. Still it only changes the compression and extension measurements. It doesn't change the difference between them. Measuring from the center of the hub isn't really mandatory as we are realizing. Different flares and body lifts through everything out of wack. I should measure my static to see what the comp and ext distances are.
Either way, the extra travel I have is due to the arms. There's no way to get that kind of travel with stock arms or even arms that utilize the stock ball joint. Previously, the balljoint boots contacted the coils on my setup. The upright fell between coils on one side.
kawazx636
10-06-2021 03:03 PM
TheBFA
02-15-2020 06:55 AM
dirk89
10-01-2015 05:15 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
