I need help with rebuilding the aisin manual locking hubs for 86-95 IFS
i am buying a pair(used) of the aisin hubs to replace the A.D.D. on my 4runner. i was thinking that since i have them off and if it isnt too hard i could rebuild them and paint them and make them look and work like new. i was also wondering if anyone had a pic of all of the nessecary hardware so i know that i get every little piece for the install. thanks
they are a peice of cake to rebuild. all you do is take them apart and replace 2 gaskets and clean everything up. when you take them apart to paint make sure you do NOT loose the ball and spring. i lost my spring, but i had a spare set of hubs, so i just used the other hubs. hope it all works out
Originally Posted by surelly09
whats the spring and ball bearing do??????? i mean why are they there?
Try your local dealer...
http://www.marlincrawler.com/axleparts.html
or any other place that sells Toyota parts...shouldn't be hard to find at all.
Here ya go
http://www.pnw4runners.com/pdf/AisinHubs.pdf
found it in this thread
https://www.yotatech.com/forums/show...&highlight=pdf
SO if those are missing, the hubs will turn will turn to the free position on thier own? Because when i rebuilt mine they weren't in there at all... and I have never had a problem with them
ok i got the hubs and am now having trouble re assembling them. i can not get the last 2 major pieces to set flush, something isnt lining up and i cant figure it out HELP!!!!
These might help you out also....
http://www.autozone.com/servlet/UiBr...3d80161e76.jsp
http://www.4x4wire.com/toyota/maintenance/front_end/
make sure you get those springs in just right
is this on the truck or off the truck that you can't turn it to lock?
the spring isnt in the right poisition when u put it together. you need to take the hub off the hub body and turn it so that the spring becomes compressed. than put it back
That link that S_wall linked to my site is from the "CD" version of the FSM.
