gears or locker
Old 09-01-2005, 04:33 PM
924runner's Avatar
Gears or Locker?
i am thinking of getting a lock right locker.
but i came across these 4.56 gears from a v6(whole third member just bolt in)
the guy selling them says they will bolt into my 4 cyl diff ,is this true?
if i buy the gears i will eventually get a locker but not for a while.
my truck has a 22r-e with a cam and 35" x-terrains. i often pull a 17 foot boat. i dont need the gears for 4 wheeling but could maybe use them on the street.
locker is $375 cdn
gears are $250 cdn rear
$350 cdn front
Old 09-01-2005, 05:47 PM
924runner's Avatar
gears or locker
i found some gears 4.56 complete with 3rd member for $550 cdn for both (front and rear),they are from a v6 will they fit my 4 cyl.
i can get a locker for my stock 4.10 for $375 cdn
i pull a 17 ft boat sometimes and i also have 35s
i have a 22r-e with a cam
Old 09-01-2005, 05:50 PM
EWAYota's Avatar
im pretty sure no one is answering right now since you'll find all your answers if you do a search.
personally, if I had a 22re and running 35's with stock gearing, I'd regear, but if I was thinking about putting a locker in the rear, I'd save up for the locker too, then get the locker put in before I put the diff in to save money in the long run.
Old 09-01-2005, 06:21 PM
Keggo's Avatar
I would say get the locker. If you get it you'll have much better traction when 4-wheeling as opposed to a bit more "power" from the higher gear ratio in an open diff.
Old 09-01-2005, 06:55 PM
Silver_Truck's Avatar
Get the locker...4.56s aren't what you need for a 4 cyl with 35s...you need 4.88s minimum usually 5.29s for 35s.
Old 09-01-2005, 07:33 PM
masterwacker's Avatar
and to carry the motion I will also say get the lockers. 5.29s are what you want in the diffs. IMO to get 4.56 and still be open will be a waste of money. You would also need to get 4.56 gears installed in the front. Get the locker and save for new gears. that is what I would do.
Old 09-02-2005, 05:13 AM
ZUK
ZUK's Avatar
456 misses the mark for making up for 35" tires.....
Old 09-02-2005, 06:03 AM
geneius's Avatar
Lockers will not help you pull your boat, the 4.56 gears will. I'd do the gears first and then the lockers later - especially with those 35s.
Old 09-02-2005, 07:55 AM
RED 85's Avatar
gears!
Old 09-02-2005, 08:08 AM
deathrunner's Avatar
4.56 isn't enough gear, you want 4.88's or better yet, 5.29's
If it is a daily driver 4.88's might be better because they won't rev as high, but 5.29's will pull harder.
locker is cool for offroad, but for towing you're gonna want a locker that you can turn off, so a 375.00 locker probably ain't gonna be the best choice.
Old 09-02-2005, 08:36 AM
Ironmike4x4's Avatar
Economically you are better off with gears for towing. Worry about the lockers later as said before.
Old 09-02-2005, 08:43 AM
bryanr's Avatar
I'd go with the gears also.
Old 09-02-2005, 09:07 AM
99_Runner's Avatar
Gears Gears Gears.
Old 09-02-2005, 09:42 AM
GodwinAustin's Avatar
I would say gears, but I agree I dont think the 4.56s will be enough for what you are looking for, especially towing with 35s.
try to find some 5.29s or get some smaller tires.
Old 09-02-2005, 10:05 AM
I think its kind of funny how this thread in general tech is solidly for gears yet the one in offroad tech is biased towards the locker...Anyway I say locker or save as the 4.56s will be a waste of money with 35s
Old 09-02-2005, 10:40 AM
Robinhood150's Avatar
Not anymore...the two threads have now been merged.
Old 09-02-2005, 10:55 AM
Flygtenstein's Avatar
4.56 gears with 35's are a waste.
Do you know what gears you have now? If your name is your rig, you may already have them.
If I towed a boat regularly, I would think twice about running a stock geared 4 cylinder on 35's.
Changing diff gears alone makes a very small change in wheeling. Adding t-cases is where it's at.
oldirtydirt
02-23-2020 09:30 AM
malteserunner
Early Land Cruisers (Build-Up Section)
89
02-09-2018 06:59 AM
jerusry
10-19-2015 05:28 PM
Daneums
07-28-2015 11:57 AM
coffey50
07-28-2015 10:55 AM
Quick Reply: gears or locker
