Ball Joint Spacers and 32s
I think I'm going to do the ball joint spacers on my truck which is stock right now. A friend of mine is looking to unload the 32x11.5 MT/Rs on his 85 4Runner with like 3.5/3.75in backspacing black steelies. I was thinking about buying these for my 91 truck but, I'm wondering if anyone has been running this setup and experienced any rubbing and how you resolved it?
One thing I think I understand but am not positive about is the compression travel with the BJ spacers. I think that the axle travels up to the stock point of full compression, but since it has been lifted 1.5" that's and additional 1.5" it has to compress so that's where the added travel is. I just want to make sure it does not compress 1.5" past the stock point.
Thanks for your imput guys!
It won't go past the stock travel points in the up direction as long as you don't remove or cut down your bump stops. It's the bump stops that determine your limits of travel. Now if you are using the BJ spacers to add 1.5 inches of lift then its possible you won’t be stuffing your wheel as far up as before. Whether or not you do depends on your t-bar adjustment, weight, speed …etc. Now in the down direction you will gain an extra 1.5 inches of travel.
I am thinking of adding the ball joint spacers as well. If I install the spacers and then set the torsion bars back to the original ride height, what does that do to my travel up and down? I understand at the stock ride height that my ride should be softer, and in addition to new shocks i hope the ride on the trail will improve. Are there any reasons I should NOT lower the ride height back to stock after the spacer install?
Sponsoring Vendor
Ball Joint Spacers
Here are some options for 2nd generation 4runners. Ball Joint spacers are available seperately for $109.00 which includes shipping in the conus. For more information contact: info@trdparts4u.cominfo@trdparts4u.com
Try this link for some options:
https://www.yotatech.com/forums/show...96&postcount=1
Hope this helps...........
Mine is a pickup so I don't need any coil spacers and whatever just doing an AAL in the rear. Do you guys have a package for just the front? Ball joint spacers and shocks that is,a nd what is the cost?
Sponsoring Vendor
BJ spacers $109.00shipping included.
Shocks $64.85 each plus shipping. for quote to your zip code send your inquiry to:
info@trdparts4u.com
info@trdparts4u.com
Sponsoring Vendor
Originally Posted by 91Toyota4x4
OK, does anyone have pictures of a truck or runner on 32s with the BJ spacers??
Sponsoring Vendor
33's with BJ spacers and OME parts
I used the SDORI 1.5" BJ Spacers, a slight crank on the T-Bars, OME N72F & N98 Shocks, OME 901HD Rear Springs, OME SD33 Steering Stabilizer. I also used the SW 26mm T-bars but that is not needed unless you plan on putting a heavy bumper and winch on. Some people have to flatten the pinch weld on the inside of the fender. I did not have to. It is very easy with a BFH. Here is a link with the different kits we sell.
I hope this helps............
I was wondering why you use coil spacers with longer coils... Isn't there any brand that do custom sized coils? Here there is a brand of coils (Mines are), Mabilsa, and you can order for example, the same coil as mine but 2'' longer, or with the wire oversized...
[Hijack on]
Hey strap22, nice looking rig, do you have any bigger pic of your truck? I just want to see how much the tires stick out of the fenders. I have 31's and fender flares but with my wheels they're near stick out. I want to see this because here it's mandatory that the wheel is covered and not stick out.
Thanks,
David
[Hijack off]
[Hijack on]
Thanks,
David
[Hijack off]
Sponsoring Vendor
[Hijack on]
Thanks,
David
[Hijack off]
[Hijack on]
Thanks,
David
[Hijack off]
Hope this helps............
Sponsoring Vendor
Why use Coil Spacers?
[Hijack on]
Thanks,
David
[Hijack off]
[Hijack on]
Thanks,
David
[Hijack off]
Hope this helps..................
Sponsoring Vendor
Thanks strap, very nice looking rig hehe.
David
David
David,
Thanks for the kind words. It's a "Mall Poser". I'll try to get some new pictures posted.
Guest
Location: Las Vegas.. Soon to be heading for south america in the 4R
anyone know where i can find some quality bj spacer install write ups? the one roger has is alright but i need it explained a lil more thoroughly.. im mechanicly enclined, not educated..
Have you seen this write-up? http://www.sdori.com/spacerinstall.htm
