4.56 or 5.29?
Old 02-02-2015, 04:46 PM
ashersullivan88yota's Avatar
4.56 or 5.29?
I Keep getting told two different gear ratios for my 88 pickup on 35's it's my daily driver suggestions please?
Old 02-02-2015, 04:53 PM
JasonYota's Avatar
What engine and trans do you have?
Old 02-02-2015, 05:02 PM
Carb0n's Avatar
I run 5.29s with sbc, th350 and 37" iroks in my 85 pickup. Love it.
Old 02-02-2015, 05:13 PM
Just a 22re I just built it its bored 20 over but with stock trans my problem now is starting off and it won't go but 55
Old 02-02-2015, 05:15 PM
Carb0n's Avatar
What gears do you have now? I have always been told 5.29s for 35-37.
Old 02-02-2015, 05:17 PM
4:10 I believe
Old 02-02-2015, 05:20 PM
Carb0n's Avatar
Old 02-03-2015, 04:58 PM
james92toy's Avatar
What transmission do you have ?
I had a 85 4runner 22r , 5 speed, 35" with 4:88 . Did good for all around driving.
If i were to do it again i would have gone 5:29
If you live or drive more in the mountains i would go 5:29.
If your ever think you might go bigger tires go 5:29
If you have an automatic transmission you might want to go 5:29 to help that 22r turn that transmission a little easer.
Just my opinion .
Get lots of opinions from people that are running those gears cause its to expensive to redo ! Call and ask marlin crawler or Daves off road.
Old 02-03-2015, 05:51 PM
Thanks man only thing I've heard about 5.29 I can't go faster than 55
Old 02-03-2015, 06:39 PM
james92toy's Avatar
You could do 4:88 and try them out . They come stock on some 2nd gen 4runner. You could just swap the diff's or just the rear first to drive around town to see if you like them . Should be cheaper than getting new gears .
I did that to my friends 86 4runner that was running 33".
Look here for diff info
http://home.4x4wire.com/erik/diffs/
Old 02-04-2015, 04:53 AM
I'm probably gonna go with 5:29 just because of all the hills and mountains around where I live and there is a possibility that I might eventually go with bigger tires i don't drive on the interstate anyways
Old 02-07-2015, 08:56 AM
aztoyman's Avatar
I'm running 5.29's in my 88. Was perfect for the 22RE when it was my daily driver. Now that I have a 3.4, I think I could have gotten away with 4.88's.
Still glad I went with 5.29's because I want to eventually go with 37's.
Old 02-07-2015, 12:56 PM
Fossilized
Staff
dropzone's Avatar
in 20+ years ago i learned my gear lesson. 84 X-cab, put 33's on it and 4.88's it was great. a few month later went to 35's and regeared t0 5.29's. It was an expensive lesson to gear for what you should.
I DD my 81 50% of the time with 35's and 5.29's, my speedo is pretty close to spot on and I can do 65 with ease.
Lifted Toyota trucks with big tires aren't made to be a Vette, they handle like an outhouse on a skateboard.
Old 02-10-2015, 10:35 AM
justdifferentials's Avatar
I would suggest going to 5.29 gears. We also offer complete third members custom built for you. If you have any questions or need a quote let us know.
Old 02-19-2015, 03:13 PM
ridecbr954rr's Avatar
87 on 35" 7years not one problem 5.29s highway speed when needed plenty of torque when needed also found e3 spark plugs really help to
Old 03-13-2015, 11:05 PM
dromomaniac's Avatar
Originally Posted by Carb0n
My truck came from the factory in Japan with 4.56 and 31"
YotaLogic
12
11-17-2015 06:27 AM
toyotasaurus
09-24-2015 03:30 PM
justdifferentials
09-05-2015 06:52 PM
coffey50
07-28-2015 10:55 AM
Quick Reply: 4.56 or 5.29?
