Last edit by: IB Advertising
- Toyota Tundra How to Repair and Replace Parking Brake
Step by step instructions for do-it-yourself repairs.
HELP!! Front end vibration....unknown source
I have a 2000 Tundra SR5, I have put the Tuff Country 5" lift on with Fabtech adjustable coilovers that are up about 2" more so I am sitting pretty at about 6 1/2 to 7...... Here is my question.... I have just recently had new CV axles replaced at Les Schwab and new 315/70/17 tires on. After the axles were replaced I notice an annoying vibration in my front end while around the speeds of 65 to 75 mph. I took it back and they replaced the axles again with brand new ones and even had the tires replaced with a completely different brand and rebalanced umpteen times and it has not fixed the problem.... everything is solid, no movement in the sway bar or control arms... would it be something to do with bad wheel bearings or something? It is definitely speed related cause it stops under 65 and doesnt stop when I throw it in neutral while at vibration speed. Any ideas or similar problems? Any suggestions or help would be greatly appreciated!!!! Thanks!!!
Flying91
45
04-11-2024 04:39 PM
jasonty
41
12-23-2018 01:00 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
