99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
2007 4.7 dcab 4x Tundra
Old 01-23-2017, 01:53 PM
helidriver's Avatar
I started up the truck this evening and suddenly the engine light came on, transmission light on, trac light on, and the hi and lo 4x4 lights are blinking and the vsc light is blinking.....???!???!
drives fine, temp fine, rpm/speed ratio seams fine. Whats wrong, where do I start for trouble shooting, what gadgets do I need? Thanks.
First problem since new....
Old 01-23-2017, 05:31 PM
Fossilized
Staff
dropzone's Avatar
when you say engine light do you mean check engine light?
How many miles? 10 years old you may have hit a preset warning for something like a timing belt or....
first step is to take it to an automotive parts store and have the codes read.
or get a code reader yourself and pull the codes, than google them.
Old 01-24-2017, 01:18 AM
helidriver's Avatar
Yes
Yeah that was the plan. 85,000mi. Seams alittle dramatic for a preset. Yea the check engine light..... and almost EVERY other light as well....
Old 01-24-2017, 01:26 PM
Fossilized
Staff
dropzone's Avatar
i'd call the dealer
i think the timing belt is supposed to be changed at 7 years or 90k'ish
what codes showed up when you had them pulled?
Old 01-29-2017, 02:46 PM
helidriver's Avatar
Sorry, finally had time to pull the codes:
https://www.yourmechanic.com/article/p2442-obd-ii-trouble-code-secondary-air-injection-system-switching-valve-stuck-open-bank-2-by-parker-hill
electrical and emissions are my weak areas. This gonna be in the haynes?
Old 03-19-2017, 11:06 PM
helidriver's Avatar
Ok ready to order air check valves for 2007 4.7 tundra, but the 2006 shows two, the 5.7 show two, but the 4.7 shows just one? Anyone kniw if the others have a specific right/left and the 4.7 just has one or dies it mean the one can be used for the right or left but still requires two? OR does the 2007 4.7 really only need one?
