Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
93 cruiser loss of power
Old 08-02-2010, 05:36 PM
bugsy1974's Avatar
i had a loss of power and hesitation so i changed the fuel filter , i thought that was it but no. so i looked at the maf and i bought a can of maf cleaner best they had sprayed it very lightly and let it dry . i reconnected the harness amd started the engine now the check enginer light is on and i have little power it will go about 70 mph but down hill going up it will go about 30 mph . i am lost i disconnected the power over nite to reset the ecu but nothing can someone help me thanks.
Old 08-03-2010, 03:41 PM
fourtrax's Avatar
you can use a paper clip to jump the te1 and e1 pins under the hood to read the codes. go to ih8mud, then the 80's section search for paper clip and you will get the info and the codes that should help you diagnose the issue, or at least provide some more information.
Old 08-03-2010, 05:32 PM
bugsy1974's Avatar
ok thanks i appreciate your help.
Old 08-12-2010, 04:04 PM
martinfan30's Avatar
Need to know what DTC's are stored in the ECU. Cleaning the MAF sensor works half the time. The half of that time, it wipes out the MAF sensor.
Typically, when a MAF sensor is dirty, you will see a hesitation off of idle. Not an overall power loss.
I would first check compression, wet and dry. Then a fuel pressure test. The ignition side of this engine rarely fails. If compression varies more than 15% wet to dry, you have compression issues. Rings and pistons.
Old 08-24-2010, 11:43 PM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
or just go to Mud, period...
This sub forum is only one page...
80's TECH has 10's of thousands...
Sleaker
08-26-2020 06:03 AM
tj884Rdlx
08-28-2015 12:04 PM
Tacoma1313
08-17-2015 05:44 PM
terminator
07-27-2015 07:13 PM
gmonnie123
07-26-2015 02:44 PM
Quick Reply: 93 cruiser loss of power
